Re: Expresso stain on Maple.Need some Help!
Bart Goldberg
Mark,
I also suggest you use a combination of water based dyes and pigment stains. The water based dyes tend to give you a more even coverage as they penetrate the wood better than pigment based stains. Here is what I'd do:
1) First, wet and pre-raise the grain of the wood (using distilled water) and lightly sand down with 220 grit and repeat.
2) Then, apply the water based dye and let it dry. Very lightly sand with 320 grit if the grain is still raised.
3) Then, I'd apply a coat of shellac to seal the dye. Zinser seal coat would work well for this.
4) Then use something like Barleys gel stain in your color of choice to add additional color and depth. This is essential adding glaze to your finish. The Bartleys will lay in the grain of the wood. Be sure to wipe against the grain and lightly so as to not remove to much stain. When the Gel stain dries, lightly buff the surface with a soft cloth to remove any residual stain in preparation for applying your finish coats.
You can get the water based dye from Homestead Finishing supplies (Jeff Jewit). You can probably locate a dealer for Bartly's Gel Stain in your area via Google or their web site. Zinser seal coat is sold by the Big Box stores.
Regards
Your BFF
Bart
