OT Videos from Computer to TV??
Thomas Norton
What device would I need to watch videos,old TV shows,etc. on my tv,in another room, from the internet on my computer?
I see that Netflix suggests a device called Roku.
So I would appreciate your advice.
Thanks,
Tom
Re: OT Videos from Computer to TV??
Stuart Johnson
With Roku you get a bunch of channels through your home net. We only use it for Netflix streaming movies and it works well for that use. There a a bunch of others but most don't have much content or are pay for use. Unless I've missed it I don't think there is a way to use Roku to stream from web content.
Thomas Norton
So ,being tech challenged, I guess I will need to have a wireless router? If so is there a brand that is to be considered?
Thanks!
John McGaw
I can think of a few answers. How far apart are the TV in 'another room' from the computer where the videos live? What sort of video quality are you looking for (regular old TV or HD)? What sort of video/audio outputs does the computer have and what sort of video/audio inputs does the TV have? At the very simplest, if the TV and the computer both have HDMI and they are within 40-50 feet of each other a simple cable between the two will do the job. If you need to have seamless control of the computer playback from the TV location this method becomes more comples.
The ROKU boxes are pretty nice but for simple applications they are probably a massive overkill and expensive to boot -- they excel at streaming from online sources and such. If you have an old computer lying about and already have networking (wired or wireless) it would be essentially free to place the old computer next to the TV, hook them up, and then play back video from a network share.
Howard Norman
John, as a matter or interest how much computer power would one need in a computer to do as you suggest?
howard
John in NM
Presumably this is a desktop computer :D
I've hooked my laptop up to the tv, simple as a VGA cable and a couple keystrokes. But I don't know how long a VGA cable you can get. Also older tv's won't have a VGA input.
I tried it as well with some kind of VGA-HDMI adapter, and it didn't work so well, noisy signal. But I didn't spend a lot of time messing with it either.
No experience with set top boxes, I'm a cheepskate :D
John McGaw
Very little. New computers designed for such tasks might have as little processing power as a dual-core Atom 1.6gHz. I find that the graphics provided by the newer Intel chipsets is sufficient for 1080p HD viewing. My own HTPC has more processing power in the form of an Intel Q6600 processor but this is way more than mere streaming of video calls for. Same thing with storage -- a few hundred gB will store a lot of HD video and if it is streaming from the home network then even less is needed. To me the biggest requirement for a layman-friendly setup is to have a computer with an HDMI connector which carries both video and audio and the proper computer drivers to support it.
You can have things like multi-tB disks, video capture and tuners and use the computer as a PVR with the right software and mine has them but I virtually never use it since my DirecTV PVR is so much more convenient.
Just my $0.02 of course...
JimG
We dropped cable a few months ago. I bought a inexpensive desktop at BB with DVI video built in, ran an ethernet cable to the computer via the basement. Wireless did not work well, I found, for video. We have DSL 6MB and it works well, even for two TV's. Our tv's have an input for sound if you use DVI video. One reason I went with a computer is to not be limited to what Roku and other boxes choose. You can watch shows from Netflix, Hulu and Network web sites. There are other sites around also, so I did not want to be boxed in to what I could choose from. So far, we have been very happy with the setup.
JimG
