Spyder Blades for reciprocating Saws???
While at Lowe's I saw a little kiosk with a film loop exposing the virtues of the Spyder line of blades for reciprocating saws. they have a number of blades, including a saw blade with teeth all the way around so you can make plunge cuts and cut in either direction. Looks like it might be useful for demo work.
They also make a grout "saw" that looks useful.
And a set of scrapers or chisels that allow for removing tile or anything that is glued down. Also looks interesting, but I wonder how hard it would be on the saw. Are these saws designed to have strength and power on the pull stroke, but perhaps not so much on the push stroke? Would it damage the saw to use it on the push stroke all the time? Interesting looking blades though.
Re: Spyder Blades for reciprocating Saws???
Howard Norman
I was at my local Lowe's yesterday and asked about the Spyder blades. I was told that they were only available online. Did your store actually have the Spyder blades?
Yes they did. They had a display of them with a video on top of the display running a loop of how great they were.
I happened to see that they had ShopSmith brand sand paper for a ROS. I tried to look it up on line. Went to the national site and it did not come up. Set the store location to my local store and there it was. Struck me as peculiar that they web site did not show it until I set it to my store.
You might try looking at the Spyder stuff by setting "your" store to Zip code to 23831.
Howard Norman
Thanks Barry. The salesman at my local Lowe's said that the store had called headquarters after customer inquiries and were told that the
Spyder blades were not in any of the stores only online. So someone is lying, either the local store personnel or the corporate people. I will check it out online as you suggested.
Doug Garnett
We created the loop you're seeing in-store. The product should be in all Lowe's stores. You'll typically find a free standing display near the Contractor Desk. They also stock some of the Spyder product in the primary tool department.
Rick L
Rick L
http://www.anglebuster.com/tools.php
Check out the Boar Blades
Wow, those could be dangerous, but the concept makes a lot of sense.
