We value your privacy.
I posted a few days ago about the Diable Sandpaper for a ROS at Lowe's and got no response. (Has Nobody tried it?)
Then I went to Lowe's. They have added ShopSmith sandpaper for the ROS to their line up. Sort of pale grey green. Claims to be a ceramic that will last up to four times as long. Anybody tried it? (I don't like the Gator Brand they have in black and garnet red. Don't get much life from it.) Or should I just break down and order some from Mirka? Or where? What are you liking for your H&L ROS?
I buy my paper from Baer supply .Its a cabinet supply co. here by me but they are nation wide supplier.The sandpaper I get is comparable to Mirka and runs about $12 for a box of 50 5" 5hole
I buy all my sandpaper from Klingspore (WC sponsor), I have used Mirka, 3M and many other brands. Klingspore equivalent quality paper has preformed as well or better than any other I have used. I purchase several boxes of discs at a time - usually also buy my belts, sticky back rolls and flat paper at the same time so freight is adsorbed. They do have some "cheap" disks which work well for rough work and sanding painted wood - (throwaway quick type jobs) as well as medium and very high quality goods. I have some of each as use them as the job requires. I am a very happy customer both with their shipping and quality.
I used that stuff once, it was horrible. As a result I tend to be pretty leery of buying paper there, since there's usually a Home Depot near by and I can just go and buy their Norton paper. I did just buy some of the 4 1/2" angle grinder sanding discs at Lowes and they've held up well. I'll go see if I can find the label for them - I don't remember the brand.
Turns out the 4 1/2" discs I bought were Gator too. Must have blocked it out in a moment of desperation They've held up quite well too, so either they've improved their grit or the angle grinder isn't as hard on them as a ROS (yeah, right )
