We value your privacy.
Is the wood ebony, or cocobolo, or what? I think you can order ebony from Amazon.com, which I guess makes it an amazonian wood. If it is a nice hard wood, I would probably put the Thomspson's water seal on outdoors as suggested, but I would leave the indoors unfinished. They would kind of wear naturally and have a country look to them over the years.
Hello Mariel. (It seems strange to be talking to another Mariel. I have a daughter named Mariel.)
First, indoor and outdoor applications are completely different from each other. For a beach house, I'd recommend polyurethane varnish on the interior floors. It will preserve the rich color and resist the inevitable abrasion of sandy feet. Be sure to test whatever varnish you use on a sanded scrap of your wood, because many tropical hardwoods have chemicals in them that impede drying, and you end up with a gummy mess. If the varnish doesn't dry hard in a day or so, you may have to shellac the floor first to act as a barrier coat for the varinsh.
The deck is another story. It will want to weather to gray no matter what you put on it, unless you are religious about reapplying finish on whatever schedule is necessary, which could be once or twice a year, depending on the finish. There are lots of "deck finishes" out there. Most are pigmented oil stains. Some, like Cabot's Australian Timber Oil are mixtures of oils and alkyd resins, driers and UV inhibitors that will keep the color looking good, but you'll need to apply them regularly or they will eventually allow the deck to start to turn gray. You might want to try one of these and see if it dries. I actually recommend putting them on very thin and wiping off the excess. This keeps the film from remaining sticky.
Another product that a friend has recommended is Penofin, which is more of a penetrating finish. He swears by it. In fact, maybe he'll weigh in here and tell you more.
First, as Ellis has said, interior floors and exterior decks are two different animals. There is not a more durable for interior floors than finish particularly formulated for use on floors.
Exterior surfaces are more difficult to deal with. Sunlight and large swings in temperature and relative humidity will rapidly attack finishes and the wood underneath. Some tropical woods will last forever without any treatment. The Atlantic City boardwalk is Ipe and is probably 75-100 years old.
One suggestion is to go to your local library and take a look at the June and July issues of Consumer Reports. CU runs a continuing testing program of exterior deck products. They report their current results in the issues noted.
It would be helpful to know how the Watco was applied. I agree it's a very poor choice but it will have to be removed before any other finish can be applied. Knowing how it was applied would be helpful with knowing what to recommend for removal.
Red Oak has a janka hardness rating of 1260 and cumaru or shihuahuaco or Brazilian teak (whatever you want to call it) has a hardness rating of 3540, or almost 3 times as hard as red oak. If this is kind of an informal villa or cottage leaving it unfinished seems to me like it would work very well. We live in kind of a country style house and I have done a number of door casings in unfinished rough sawn white cedar and we like the way it looks. You can put a film finish on it and make it glossy but it will need to be recoated every 5-10 years where if you leave it unfinished it will be good for a couple hundred. If you do decide to try it unfinished and find out you don't like it, you can always just sand it and finish it.
The Watco was applied in a way that would make any wood lover cry!
The workers applied it thickly with a brush and left to dry. It was not wiped dry as per the Watco instructions. Days later when we arrived on the property it had dried but still felt sticky. Sand residues had caked on it. Footprints could be seen. The workers had no idea how to work with the product and neither did the contractor, obviously. Too sad! Now on to the next step, the removal of
This thick guck! We will do it ourself. Please advise. Thanks ml
Since WATCO is an oil-based product you're going to have to "strip" your new deck. With your description of the "sticky" surface, it should come off r=fairly easily with deck stripper which you can buy by the gallon at one of the big-box stores. You'll also need a broom-handled stiff scrub brush, and a water source. A 1600 psi powerwasher will be a very large help.
If you can, powerwash the decking first with water and detergent, this may remove a fair amount of the excess product that's sitting on the surface. Next apply the stripper to small (6'x6') sections according to the instructions on the jug. You will be wearing rubber gloves, safety glasses, plus long sleeves and pants (old clothes!). Allow the stripper to work for at least 15-20 minutes, then scrub with the brush(s) and rinse or powerwash the surface. When you've completed the entire deck, mop on a very mild acid solution (1 cup muriatic to 1 gal. of water) to fully neutralize the lye in the stripper. Rinse well and let dry. When the surface dies you'll be able to see how well you did and whether you need to do it again.
Consider sending the idiot builder a bill for your time, materials, and equipment.
Are Sikkens SRD and Penofin (as Ellis already suggested).
I've used both on Ipe, they are far better than Cabots and the like in my view. In my area, you have to go to a real paint store to find them, hardware stores and home centers don't carry either product.
I just want to reiterate the joys of natural hardwoods allowed to weather to grey. A light powerwash (I've used a wimpy electric power washer) makes it easy to clean up occasionally. I've used Messner's UV on ipe with success, but even so if you have one year where things get too hectic to keep up with it, you are doomed to stripping, sanding and/or heavy powerwashing. Grey is better.
Didn't realize y'all were out of reach of a Home Depot. Lye-based paint stripper is pretty innocuous; I'd venture (but not wager) that you can find a similar product locally.
