Installing cabinetry molding with "perfect" joints
Bill Tindall
Many sorts of cabinetry have a "wrapped" molding such as the molding at the foot of this Period piece from Greene County, TN now in the Allendale Mansion in Kingsport. The challenge is to get the length of the three pieces of molding, as well as the miters, perfect.
Step 1 To begin cut the three pieces of molding a bit long, say 3/8" too long and miter the ends at 45 and 90 degrees. These three "rough cut" pieces are shown in Picture 2 on the chest of drawers they are to be installed on. Depending on all the stuff that can go awry the miters may need to be slightly different from 90 and 45 to perfectly fit so some diddling is usually necessary.
Step 2 Test fit the miters on one side of the piece as shown in Picture 3. Because these pieces were cut with extra length the 45 degree angle of the miter and the 90 degree angle of the miter can be adjusted/trimmed to get a perfect fit. Repeat this fitting of the miter on the other corner but when this second corner is perfect leave the settings of the miter trimming devise unchanged. At this point in the process you have perfectly fitting miters on each corner, and, all three pieces are a bit longer than they will eventually wind up.
The miters can be trimmed on a table saw or a more precise way of nibbling miters into perfection is with a donkey's ear, an oddly named tool if ever there was one. You can see the mitered piece in the tool. A hand plane edge rests in the groove in the MDF and the other side of the plane rides on the sloped top piece. By shimming the molding against the stop and base of the tool the miter angle can be adjusted both +/- 90 degres and +/- 45 degrees.
Step 3 Return to the first miter adjusted(in this case the right side, get the two pieces perfectly aligned and clamp the side piece in place as shown in Picture 2.
Step 4. Now turn you attention to the left miter. Recall the tool setting remains perfect for trimming this miter for a perfect fit. Nibble away at the miter on the left side to get the length of the front molding piece perfect to fit the miter on the left side while at the same time the miter on the right side is aligned. These test fits are done by hand holding the front and left side molding while the right side molding remains clamped in place.
Step 5. When the front molding length has been perfectly trimmed, by saw or donkey's ear or whatever, glue it in place, carefully aligning the right miter as shown in Picture 4. (Whoops, I have already removed the clamped molding from the right side when I snapped this picture. It needs to be there while gluing to enable the front piece to be aligned properly. Of course it can be removed once the clamps are applied )
To keep this molding from skidding around while applying the clamps it can be useful to drive three tiny brads along the length of the case where the molding will be installed. (Do this after the molding has passed its final fit) Cut the heads off, leaving about 1/16" projection. Now press the molding back into place such that the brad points pierce the molding to make a dent. The dent and brad point will perfectly realign the molding when it is reinstalled after glue is applied. I always apply glue to both surfaces of a joint to ensure wetting of both surfaces. Wetting is essential for adhesion.
Step 6 Test fit the side pieces and trim to length. Now it is a simple matter to glue the side molding pieces on, aligning them with the miter of the front molding. Because this is a cross grain application glue is applied to the miter and the first 3" of the molding only. The remainder of the molding is nailed to the case side.
Re: Installing cabinetry molding with "perfect" joints
PS, the plywood piece is the molding pattern
Jesper, Denmark
Re: PS, the plywood piece is the molding pattern
Jesper, Denmark
Hi Bill,
Aren't you asking for cross-grain troubles by gluing the side moldings across the rather long vertical grain of the sides?
I am right now working to repair just such a chest, where on one side the glue failed and the top molding fell off and on the other side, the glue held and the side panel split.
nickb
I wasn't able to see the picture of the "donkey's ear" tool. Is it a problem with my pc or an upload issue? (when I tried to open the image separately, it told me the file doesn't exist on the server)
donkey's ear picture
Bill Tindall
Woodcentral has some posting problem. Pictures I down loaded kept vanishing as I continued to composed the post. I tried to add them back and apparently missed this one.
Jesper, Denmark
Re: Got it.....
Jesper, Denmark
On the other hand, would screwing from the inside not be a better solution - if access is possible and with some elongation in the screwholes?
In my repair project, there is no access, so the nail solution is the only one.
nothing wrong with nails
Bill Tindall
Nails work and they are period correct for this application do there is three hundred years of successful application experience. Screws will have little purchase in a then molding like I have.
