game table hinges
HapaJeff
I have an unusual situation that I'm looking for a solution for. I'm changing the hinges on an antique game table. At some point in the past, some yahoo changed out the hinges, only to use a Soss-type hinge, which is not only inaccurate, but looks out of place as well. Here's the kicker for me: the table doesn't have straight sides. "Normal" game tables are rectangular when closed, and square when opened; at least they're straight where the two halves come together. This table has an undulating side. I've attached a sketch for clarification.
There are two solutions that come to mind, but I'm hoping that you might have something simpler. One solution is to bend the arms of the hinges to match the curve of the table. Honestly, this operation seems like there's a high likelihood of distorting the hinge to the point that it doesn't work. The second solution that I thought of was to cut a mortice into the side of the table to allow the hinges to work in one plane, and then plug the mortice to hide it. The problem here is that if the hinges ever need to be tightened or removed, I'll have to dig them out.
For reference, I purchased a pair of these hinges: http://www.whitechapel-ltd.com/product/cardh/244H31.html
Any ideas for me?
Thanks,
Jeff
