Hexagon Table
Mark Meier (Ann Arbor, MI)
Here are a few pictures of the white oak table I just finished building:
Here are the details on how I cut the joints: Wood Joinery on a 5-Axis CNC Router
Mark
Hexagon Table
Mark
Interesting design, indeed, Mark
The angular stretchers are a bit of a surprise - but after a little study, they make perfect sense.
Woodworker test
Bill Tindall
Someone that doesn't build furniture will simply look at the table and admire its grace. A woodworker will look and their head will explode from contemplating fitting the joinery!
BTW, I like the dog.....
Re: Hexagon Table
Moses Yoder
Is that CNC router yours, or do you just have access to it? It seems like the programming would have to be done in 3D. We used AlphaCAM for programming but the only drawing I ever did for ours was in 2D.
Re: Hexagon Table
The router is owned by the Taubman College of Architecture at the University of Michigan in their digital fabrication lab. I'm a student there.
Yes, I programmed it using Mastercam, the input to which is a 3D model which I created in a program called Rhino.
Mark
Re: Woodworker test
Hi Bill, Thanks for saying that. I designed it with all the compound angles because it was meant to be something that would be tricky with more traditional woodworking tools but facilitated by the CNC router. Loose mortise and tenon joints were used and I'm happy to say everything lined up and fit together really well.
Mark
