Replacing ROS H&L pad????
I have a 5" PC ROS. The H&L on the pad wore out. Home Depot had a replacement that is a stick on. I was a little skeptical. I smoothed the balance of the H&L off the disk and stuck it on. Its a peel and stick like a bumper sticker.
I was doubtful about the H&L, but it turns out it REALLY grabs the sand paper. IN fact, it grabbed the sandpaper so well that it pulled the disk off when I tried to change the paper. I was very careful but it came loose any way. The dust got in there and the glue completely failed. I tried cleaning it with lacquer thinner to revitalize the glue and that seemed to help, but not enough.
Any suggestions? I have a spray can of 3M 77 adhesive, but not here at the moment. I actually have two of these sanders and I did this to the other one and it worked well. I suspect I did not get the disk smooth enough.
