Drill Press Got A Little Seedy....
Robby Wright
My drill press, an old Delta Homecraft, acted like the gears that move the quill up and down were failing. The quill would stick and the lever you use to move it up and down (or should I call it a wheel?) wouldn't go past a spot in its travel. This was getting worse over time and I was thinking I would have to disassemble the drill press head - a task I really didn't want to do.
Saturday morning, as I was laying around in the early morning sleep fog, a thought came to me: Check the gear teeth on the quill itself and see if they are clogged or broken. So after breakfast, I went out to the shop and checked. There was some stuff in the teeth, like woodchips. I took a brush and brushed out the teeth I could get to and worked the handle up and down. Brushed some more, more stuff came out. But now, the stuff was starting to look like little round balls. Did it some more and realized that a mouse that has taken up residence in my shop had packed my drill press head full of some birdseed that my wife had spilled. After a couple of dozen up-clean-down cycles, my drill press is back to normal. Now to find that mouse. I will tolerate a little mouse action, but not when it messes with my tools!
Re: Drill Press Got A Little Seedy....
That mouse was probably bored
LOL
Thanks for the comic relief.
Now how did the mouse get up there??
I Wonder, Robby
George Colonel's Workshop-Havertown PA
Good Afternoon Robby,
Maybe you should plant some of those seeds and see if little drill presses grow next Spring. :b
George
time for a little close-order drill!
Re: LOL
Robby Wright in San Marcos, CA
That is a good question. I think it climbed up the cord, which is a #12/3 SOW piece with a heavy rubber cover that claws could easily dig into. More importantly: why? There are plenty of other places, so I am baffled as to why it picked under the big pulley on the drill press. I almost got a new drill press. Next time I will have to try a little less hard to fix it...... :b
Re: I Wonder, Robby
Don't know about drill presses, but maybe some new drill bits? Where is that fertilizer....?
Re: Was his name "Chuck"?
You guys never dissappoint. Somehow, though, I expected the Colonel in this part of the replies.
