Craftsman 113.298240 Issues
Clay
I was recently given an old Craftsman table saw by my a friend of my fiancee's family to help me get started into woodworking. I cleaned it up, got it tuned to the best of my ability and have been using it to make various cuts over the last couple weeks. It was working great until the other day when I turned it on and heard a loud rattling noise over the sound of the motor. The blade still turns but when I turn the motor off it stops almost immediately instead of slowing down like it used to. I've been trying to diagnose the problem and I think I'm just not experienced enough with this tool to know what is going on. I have tried the following things:
1. Removed blade, still makes the noise and the arbor spindle still stops nearly immediately when engine is cut.
2. Rotated it by hand, notice a faint click when arbor is rotated that i didn't notice when I first got it.
3. Removed belt, ran motor. Sound does not appear to be coming from motor and motor slows down to a stop normally.
4. Noticed the pulley on the arbor was loose, tightened the allen nut on the pulley this didnt seem to help the problem.
Anyone have any idea about the next steps I should take to address this issue? I'd appreciate the help!
Re: Craftsman 113.298240 Issues
Jim Hager
Does the arbor turn freely by hand? I'd suggest taking off the belt from the motor and arbor and then turn the arbor by hand. If the pulley was loose previously my guess is that the pulley is out of place and needs to be realligned on the shaft. It sorta sounds like it may be rubbing on the bottom of the table or maybe up against the bearing housing. Beyond that I'd check the arbor spindle bearings next. If it's been sitting quite a while since it's last use the bearings may have rusted up, a bit of solvent properly placed will loosen things up some then follow that up with some light oil. They are "sealed" bearings but you can still get oil and solvent in there. You may have to replace the bearings. Check all the more simple things first, likely just something out of place or not tight.
I agree with Jim
Either there's something rubbing - pulley is the first prospect because it had gotten loose* - or one or both arbor bearings have died. Take off the belt and rotate by hand. If it's making rubbing sounds/feeling like it's rubbing, loosen the setscrew and move the pulley away from the casting; try again. If there's a key (little square chunk of steel) between pulley and shaft, look to see if that appears to have moved; you might need to remove the pulley and adjust the key's location. If you're still getting reluctant movement, lower the blade slightly and test again to make sure you're not hitting the table. Still reluctant to move? Probably bearings.
That clicking noise could have been the loose pulley, something hitting, or bad bearings.
*Pulleys will self-align if one's loose - move so that the belt runs in a straight line between two pulleys. In fact, this is a classic method of aligning pulleys on purpose. If your motor's pulley is located such that the arbor pulley wants to be pulled over to rub against the casting, you may need to re-align the motor pulley.
del schisler
I didn't read the other post. Change the beiring in the arbor. My brother almost lost his finger's when the beiring came aprat. The blade cut 4 finges not they are stiff from the cut's. Change the beiring's !!! now i will read the other post's
Galen Vetterick
Some of your description is not too clear. When you shut off the motor you say the blade/arbor stops almost immediately. Does the motor stop at the same time? If the key is sheared or missing under the pulley set screw the motor can still spin the arbor and it will make a rattling sound as it slips. It may take the blade longer to come up to speed in this case. When the motor is stopped depending on the pulley slippage the blade can stop faster than normal.
I agree the arbor bearing could be bad in fact a ball retainer cage could even be broken. This would let you turn it by hand slow but at motor speed the balls will rub on each other rather than the cage and slow things down for sure when you remove power. Trying to add oil lub may "wet" the old grease but I would not depend on that running you for long.
If the arbor bearings are good you could still have a bad bearing in the motor. It may run well without the belt. The belt adds an overhung load to the motor shaft and if the bearings are sloppy the rotor may drag and cause noise and in turn stop the motor faster.
Other suggestions good points and mine repeat some.
A link to your parts if you have not looked already.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-113298240/0247/0744600/00040549/00002?blt=06&prst=0&shdMod=113298240
