200+ woodworking book reviews
battery life question
Jerry Gibbs
I have a winter workshop in FL. I will no longer be hauling tools back and forth from MI. I know I can use a corded drill motor, but I have become used to the cordless. Does anybody know of a rechargeable battery than can stand not being re-charged for 9 months? thanks, Jerry
Re: battery life question
No. If you will be using the tool, you will need to recharge. If you don't use it, you won't need to recharge as often. I've had batteries last for a good six months w/o recharging - but if you use them ....
Of course if you get a "Yankee" screw driver, you won't need to recharge it at all ;) .
the lithium-ion batteries are said to have a long shelf life - not sure if it's that long. The real question, I guess, is whether a battery that's allowed to sit that long will go stale and fail early; you can always put it in the charger the day you arrive.
I'd contact some of the manufacturers and see what they say about their batteries in your situation.
Henry Higginbotham
I assume you fly down to Florida; otherwise you wouldn't have this problem. Why not just ship the batteries to Florida via USPS, UPS, FedEx, etc.? Ship 'em back when you leave, and have year-round use from the same set. I know this doesn't answer the question you actually asked, but based on the limited info provided, it seems like a solution.
Jesper, Denmark
Jesper, Denmark
Lithium Ion batteries should do that OK. I have several, some of which do not get used very often - like an impact driver. They seem to hold up very well.
All my battery driven tools are now Makita - I do not know if that makes any difference, but at least the batteries are interchangeable.
you really don't have a choice
Bill Tindall
About any modern tool is going to have a lithium ion battery. This is a fairly new battery technology so there are many variants to the details of their construction and materials and no doubt some many be better at one attribute than another. but how would anyone but the technical staff of the battery company know which is better at this task or that, for example storage? Indeed, there are other battery technologies that have better shelf life but they don't make them to power drills.
Lithium ion batteries (NiCd and NiMH too) will typically have better life if they are stored in the mid range of charged capacity. All battery types have better life if stored cold, poorer life is used cold.
One alternative is to buy a Rigid tool and the Rigid batteries are guaranteed for life. Do pay attention to the details of documentation though to keep the warranty active.
I am a bit bewildered as to why batteries are an issue. Hauling one from here to there doesn't seem to be much of an impediment.
Tony - Memphis
Just don't store them at 100% charge and don't let them get too hot. Li cells live best stored at 40% charge. Not sure how you can measure that easily (you need access to the cells). We buy and store thousands of Li batteries. They come from the factory at 40% and will last months. Not ideal, but we can't manage our demands/needs any closer than that.
Tony
% charge ambiguity
Bill Tindall
Li ion batteries operate in mid range of maximum theoretical capacity. Below a certain percentage of total capacity the battery is irreversibly compromised and above a certain range there is risk of spontaneous discombobulation (smoke and fire if the safety features fail). Hence, all Lithium ion batteries and chargers have battery management electronics to keep the batter in this mid range range of total capacity. So for example a Li ion battery doesn't become completely discharged in use, rather the battery is shut down at a certain minimum charge and similarly shut down at some percentage of total charge.
Hence, there are two possible percentages, one for the total capacity and another for percent useful useful capacity.
Irreversible stuff happens to all batteries when they are fully discharged and different irreversible stuff happens to them when fully charged. A mid range of total capacity optimizes these aging chemistries. So, for example, your Prius battery operates around a narrow mid range of total capacity to promote long battery life. When charged to 100% of its useful capacity it is in fact a bit more than 50% of its total capacity.
The bottom line is that battery life will be shortened at a greater rate any time the battery finds itself outside the optimum charge range. But as Tony said, there isn't anything practical that can be done about it except storing the battery cool, or better cold, to minimize the effect of the battery destroying chemistry that occurs more or less at any percent capacity.
As important to battery life as storage is the temperature that the battery is discharged at and the temperature it is charged at.
