OT freezing and outdoor risers
woodenleg
I was taught to always be sure to undo the hose from the frost proof risers so they would not freeze. I reminded my wife and she said "Why?". I don't have an answer. Help Please. Dave
Re: OT freezing and outdoor risers
Outdoor (freeze proof) faucets and risers all work on the same principal - the "seat"(area where the valve shuts off the water) is not right under the handle. It is connected to the shutoff handle with a rod that extends to a warmer area so water is held only in areas where it will not freeze. The seat is usually 12 to 16 inches from the actual faucet. The hose must be removed to allow the water to drain back to the "seat", otherwise the pipe and hose will freeze and possibly destroy the pipe and flood the area when the weather warms and it thaws. The Stand up Hydrant type have a drain built in at the seat that opens when the hydrant is shut off - these are buried at least 30" deep in most areas - provisions must be made during installation to allow the drain to work - usually the bottom of the hydrant is placed in gravel to allow drainage. Even this type is more effective if a hose is removed when it is not in use to prevent a vacuum and prevent the drain from functioning properly.
John McGaw
There are 'freeze proof' sillcocks which,while costing perhaps $10 more than the usual variety, have a breaker at the hose-bib connection. Until there is enough pressure built up when you turn on the water an opening exists an outlet for drainage near the lowest external point so they should withstand having the hose remain connected. While I had a plumber out this summer to replace my water line from the main I had him replace all three of mine with this sort which I had picked up at the supplier. I figure that the originals lasted since 1964 so the better replacements should easily outlast me.
Larry Explained it well.
And you are right that they should have the hose removed in the fall or early winter. As a Home Inspector I find "Freeze Proof" faucets that have failed and burst in the tube on the cold side of the valve regularly because they left the hose attached.
Kneale Brownson
Kneale Brownson
Those devices will squirt water all over your foot if you turn off the water to the hose while there's pressure inside the hose from having a nozzle on the other end that shuts off.
