Uh Oh, Am I a turner now?
Stephen Kirk
A couple of months ago I took a one night turning class and really enjoyed it. I had an old lathe from my dad and when I tried things at home, well, results varied. I'm a big fan of Jet Tools and I saw that they really discounted the 1220VS midi lathe, and lo, I have one now. I used the regular old 1220 in the class, so I knew it was a good tool.
I figured without some turning skills I was missing an important piece of furniture building. So, I envision having a lot of fun with the lathe. I have an old set of none too sharp tools but even the sample bit of spalted maple scrap I put on it turned quite well.
The lathe is easy to adjust, even the belt changes are pretty quick, while the variable speed adds tighter control. Seems to have enough HP for the standard stuff.
One odd thing I noticed, at the lower speeds I see some wobble on the spur center. Turn the speed up and this seems to disappear. Not having done much lathe work I'm not sure if this is fairly typical or not. I did clean the tapers and I inserted with hand pressure only. Anyone else see runout at low speed?
