jointer milling question
Jerry Gibbs
Have an old Sears 6 inch jointer which flattens boards fine. When I put the flattened edge against the fence to get a square corner, it is not square. I can even make parallelograms. The fence seems sturdy. Any help is appreciated, since the parallograms keep getting smaller. Jerry
Re: jointer milling question
Bill Howatt
The obvious question, is the fence perpendicular to the table and are the blades parallel to the table width? Fences usually have adjustments.
The jointer is one of those tools where a good technique is essential, in this case, are you indeed keeping the face of the board against the fence?
Bill
John McGaw
Fence not moving? Fence at right-angles to both tables? Stock being pressed firmly against fence? There are only a certain number of things that can cause the effect you describe and these questions probably cover all of them. The only one I've had problems with is the last one and I've found that feather boards can help if the stock is proving difficult to feed -- at least you only have to take care to keep the stock down against the tables when the feather board is doing the other job.
Rejointer milling question
Jerry, check the other posts about getting the fence square to the table and blades parallel to the table. the fence must be strong enough not to deflect and remain square. You must keep the stock firmly against the fence.
And good technique should also involve alternating the face that touches the fence so that if the fence is off, the angles created will cancel each other out. Lets say your fence is off One Degree (a lot). If you alternate the faces of the boards, one edge will have an 89 degree angle and the other a 91 degree angle. They will mate together at a 180 degree angle which is what you want.
del schisler
get this beall tilt box and set up the degree's . also you can use it on the drill press also . It has magnets all you do is put it on the drill bit and zero it out than put it on the bed and zero the bed. Than it will be 90 degree's. Also it work's in any degree setting's . I wouldn't be with out it. Set's the blade to 90 degree's with the bed on the saw. Cut and past this link
http://www.bealltool.com/products/measuring/tiltbox
Hal
First joint one edge, then joint one side, then run thru table saw with jointed edge against fence, turn board with sawed edge against fence and run thru saw. Now run thru planer. This is technique suggested by Glen Huey.
technique sounds good
Re: technique sounds good
Hal
No doubt you're experienced enough that it's obvious to you, but I should have added that when running thru saw, the jointed side would be down.
