We value your privacy.
Have any of you ever painted over Oak Kitchen Cabinets? If so were you happy with the results?? Not really a big fan of our kitchen cabinets, but I don't have the money to buy new ones or the time to build new ones from scratch....
I have painted oak cabinets. I had a very difficult time getting the paint to cover, without the red of the oak bleeding through. I finally gave it a couple of coats of oil-based KILZ primer, and that did the trick. I used the KILZ Original oil-based primer:
We had dark oak cabinets in both bathrooms. We sanded them down to remove the varnish and painted them with a white semi-gloss latex. I was concerned that the porous grain would prevent a smooth finish but they turned out great. It took three coats.
I painted ours three years ago. I did not remove the original finish, sanded with 120 to give the new finish something to bite on, two coats of http://www.rustoleum.com/CBGProduct.asp?pid=223 sand with 120, two coats of 100% acrylic sand with 220.
They are holding up very well, even the doors above the stove, all the steam from cooking has not affected them in any way.
The wood grain shows through the paint, you can tell the doors are solid wood.
For a pretty looking Oak cabinet I would suggest stripping the finish which isn't hard but time consuming..
Use a Commercial stripper , like Jasco.
Sand it smooth by hand to keep the dust down and using McCloskey's Limed Oak effect which is like painting with very thin White Paint , ,then while the Finish is still wet , wipe it down with a clean Painters rag to be the effect which you like best. Then clear coat , finish your choice.
Looks very good, on New raw Red Oak,this finish will sometimes have a very slight Pink effect which seems to never bother anybody i have worked around.
Thanks for all the advice. I may even look into using Rustoleum's new Cabinet Transformations - I have never used it but have heard pretty good things about it.
