WE MOVED...
waterproofing wood for bees
darrin hill
i have 9 beehives at my farm and texas is under the worst drought in 117 years...
since we have no water, we have no flowers, and thus we have to feed our bees.
so i took a piece of plywood and drilled 4 holes in it the size of mason jar lids... i feed sugar water in the upside down jars cause i punched a bunch of 1/16 inch holes in the lids for the bees to suck out the food..
once a week i have to get the jars, take them home, and wash them..
it takes about a week for the jars to get moldy... so i wash the jars in the sink and soak them for about 15 minutes, then scrape the jars and use a sponge to clean them out..d
and i have to boil the lids cause the bees tend to clog up the holes with wax and the easiest way to clean them off is to boil the wax out..
so i can build this..
http://www.beesource.com/build-it-yourself/miller-type-feeder/
just dump sugar water in and done... but i think it still would need scrubbing... and my idea involves a power washer...
so i could do oak boards, some silicone in the corners, but was wondering what would be good to coat the inside and outside... prettyness doesnt matter... just need to make it work..
Re: waterproofing wood for bees
An epoxy finish would be water resistant. I've used a 2 part epoxy finish for coating the inside of goblets and for bar tops.
If you would like a less expensive finish, you could try a marine varnish - that would be cheaper, but not as durable as the epoxy.
A friend of mine swears by conversion varnish (2 part) - but that is a spray varnish. If you don't have spraying equipment, that does you no good.
So, my "choices" would be:
A) 2 part epoxy finish (bar finish)
B) Marine Varnish
Jim DeLaney, Austintown, Ohio
Instead of wood, it seems like using a piece of PVC would bbetter suit this purpose. The PVC trim boards being used to replace wood trim shouldn't be too expensive, and they'd be impervious to moisture, and much easier to clean.
Lowes here has a limited selection in stock. Check your local store.
John Veerkamp
could you use PVC plumbing pipe? It comes in some fairly large sizes for drainage pipes.
