Router Lift System Moving in Use
cody lewis
For some reason, my router lift system is slowly moving down on me while I'm in the middle of a cut. Needless to say, it has ruined the cabinet doors I'm making. I can't figure out how to tighten it so it won't happen anymore. Can anyone help?
It's a JessEm lift if that helps. I tried to attach a picture, but couldn't figure out how.
Re: Router Lift System Moving in Use
Rick Haverstock
Cody,
Have the same unit and had the same problem. Pretty straightforward fix: remove the lift from your table and turn it upside down. The tension adjustment is a knurled/castleated(sp?) nut that is held in place with an allen type setscrew. Loosen the setscrew and rotate the nut while testing the tension with the crank. Once you've dialed it in, tighten up the setscrew again(hint, it only fits between the indentations in the nut) and you're back in business. IIRC, Jessum also wants you to lube the thin rubber tension washer under this nut but i didn't bother; looked like a good way to catch wood dust and didn't want that. Good luck!
Rick Haverstock
Cody Lewis
Thanks so much for the help. Your solution is much better than my solution of clamping the belt. I really appreciate the help. Now, if you could just un-route these cabinet stiles for me, I'd be all set.....
Thankfully, I only ruined 2 before I noticed it was moving on me.
had same problem, same solution
Rick Haverstock
Wood filler Cody, lots and lots of wood filler....
