old table repair
Carol Reed
I lucked into an old white oak round kitchen table on the big center pedestal. It is in fairly decent shape but needs some TLC. The wooden slides are pretty sloppy and I discovered the screws into the table top were loose. The holes may be a big bigger than needed. Question. Is the one fixed member of the wooden slide screwed and GLUED to the table top? It would be a cross gain attachment. I've not removed the slides yet. Is there a way to take some of the slop out of the slides?
Also, the top boards are no longer glued to one another. The tops are held on by the attachment of the circular apron, the glue blocks being sound. Consequently there is a slight droop of the tops.
How should I proceed? I can post pictures, but that will take a bit. Still getting used to the MacBook.
