cut off sled runners
Jerry Gibbs
Does it make any sense to make the runners out of ply to minimize expansion and contraction?
Jerry Gibbs
Re: cut off sled runners
Ken Oakley Sunny St. Cloud, Fla.
I have used Baltic Birch plywood for runners. Also used Plexiglas and one time I used 3/8" aluminum.
Jim DeLaney, Austintown, Ohio
I've used the 3/4" aluminum T-slot extrusions for the runners on several of my sleds.
I get mine at Hartville Hardware, but nearly everyone carries it.
In the case of my saw (Shop Fox Cabinet Saw), it fits the slots perfectly, with no play, and it's unaffected by the weather.
Bill Tindall
I used white oak with growth rings oriented for minimal expansion. They do get more snug when the shop humidity climbs, but not unacceptably so.
Re: cut off sled runners *LINK*
Get a piece of 3/8" HDPE and cut your own. Cuts well on the TS and can be trimmed to a precise fit on your jointer or with a hand plane. No reason why you can't also fit it with a washer to run in a T-slotted saw. See the link.
Their stock size is 24x48 which will make a LOT of runners
, but the stuff is about the same in the friction dept. as nylon so it works well for jigs and other moving parts. If you call, they might sell a smaller piece.
US Plastics
PaulSV
I have used white ash for runners, and they worked well, on sleds that got a lot of use for 10 years or so. I used 3/4" plastic T-molding edging, epoxied into a slot on the edge of the runner, which worked very well. I'm sure that could be used on 3/4" plywood as well. This is the kind of stuff I use:
http://www.rockler.com/product.cfm?page=1181&filter=edge%20banding
I'd be a little concerned with moisture getting into the edge of the plywood and swelling the laminations, and about the plywood edge getting nicked up pretty easily, if you don't edge band it with something.
PaulSV
Wait a minute: I was talking about sleds that you use in snow. I just realized you were probably talking about a cut-off sled fro a table saw. Totally different thing. Sorry if I confuse everyone!
Tony - Memphis
I have used that several times. I bought the 3/4" stock. It is slightly over 3/4 and I shave it to fit. I countersing scews into it and those can even be used to expand it a hair if needed. I bought a few feet of it years ago and still have some left. Incra sells their slides that are adjustable too. Those are really nice.
Tony
Jesse Cloud
I guess I'm pretty hard on sleds and I often find that I want a slightly different configuration (e.g., wider, shorter, with guides for miters, wide holes for dadoes, special hold-down capability for curves, etc), so I find myself making them often and generally recycling the parts after the project is done. The most time consuming part was milling the runners. I now keep a couple pair of the aluminum adjustable ones around and can put together a new sled in no time at all.
Corollary to all this, my philosophy is that anything that is adjustable will need adjusting when you least expect it. So I don't bother with adjustable fences, etc. When it gets out of square, it gets replaced.
Dave Peebles Lyons, Ohio
Hi Jerry,
I use the Incra runners. They are adjustable for a perfect fit. No worries about moisture problems.
sled runners
Alan in Little Washington (NC)
I've made runners out of just about everything- UHMW-PE, HDPE, Nylon, aluminum, White Oak, etc. None slide as well as good old cold rolled steel. Steel slides the best against cast iron miter slots.
You can get a 20' (yes, feet!) of 3/4" X 3/8" cold rolled steel bar for about what it costs for an 18" (yes, inches!) runner from one of the usual suspects. If you want to go commercial get the INCRA bar with the long-wearing Nylon GlideLOCK adjusting discs.
Corian
Doug Reynolds in Seattle
I suggest you look at Corian or other brands of man-made counter-top material as it can be had for free as left-over counter-top cutouts, does not expand/contract as much as wood, is more durable and, is not bothered by moisture.
