Bandsaw blades...resoldering or welding
Joseph Mulherin
Yesterday I was using my bandsaw with my 1/2" blade and it broke. Haven't had it but about 3 weeks.
How does one grind and resolder or weld them? I am using the Shopsmith bandsaw equipment.
Joseph Mulherin
Re: Bandsaw blades...resoldering or welding
Ken Oakley Sunny St. Cloud, Fla.
Years ago I bought a kit to silver solder broken bandsaw blades from Woodcraft. Came with instructions. Takes a little practice but works pretty good. Did mostly 1/4" and smaller blades though.
JMOHNIKE
I had the same thing happen with my Shopsmith blade. I contacted Shopsmith, they had me return it to them. They determined that it broke at the weld, and they replaced it for free, Way to go Shopsmith.
So I would contact Shopsmith first.
Good Luck
Shouldn't break at the weld...
John in NM
But I had a factory supplied General blade break there too. They must put the summer interns onto blade welding their first week
I've soldered a lot of blades using a jig made out of aluminum angle. Not too hard to do and the joint usually lasts longer than the blade. Helps a lot to scarf the blade instead of butting it like they do for a weld. With the jig I made, I can clamp the blade ends in with enough gap for a file to make the scarf. The solder is a high temperature silver solder, not the stuff for plumbing. It is more like brazing than soldering.
Re: Shouldn't break at the weld...
Joseph Mulherin
Looked closely at the entire blade...it did not break at the welded joint, rather about 36" away from it....so, I shall get some silversolder, scarf the ends on my bench grinder so they mesh closely, then solder them together. I am a retired pipefitter/plumber, and like so many of us here on WC I can do, or at least try to do almost everything myself.
Joseph Most people use silver solder to put the bandsaw blades back togehter. It's much stronger. I don't know if regular solder would work.
Dick Coers
If it broke away from the weld, do a close inspection of the entire blade. It may have stress cracks in other places. Check the bottom of all the teeth, the stress cracks usually start in the gullets. If you find other cracks, it's all done for. Pitch it.
Joseph Mulherin
You were correct in suspecting that there were more cracks in the gullets...I inspected the entire blade with a magnifying glass and found SIX (6) more cracks...so, I am trashing the blade and going to have to buy another.
Joseph Mulherin
I found silver solder at Home Depot and probably Lowes too which is recommended just for metal soldering. It has an acid core and does not have to have a separate paste like regular solder.
It ranges about 425-450 degrees for working....and cost was $15.77 for 8 oz. coil.
Soft solder...
John in NM
You need a much higher temp solder than that, called hard silver solder or silver braze. It uses a borax flux like brazing but the flux typically comes as an applied paste rather than a coating on the rod. I've never seen it for sale in a hardware store.
You should be able to use a naturally aspirated propane torch still, but be patient, it's a bit slow. If you have a presto-lite or turbo torch, those would work better. You can also use oxy-acetylene, but there's the risk of melting the blade
Re: Soft solder...
Joseph Mulherin
I decided to not try to fix the blade. I sent a message to Shopsmith relating my slight use of the blade and asked what is their policy for replacement...since I felt the blade had the cracks in the first place when manufactured.
Re: Soft solder...
Bill Howatt
It seems the solders that replace the old lead-based solders have silver so they now get called silver solders and they certainly aren't what used to be called silver solder as John pointed out.
Bill
Re: Soft solder...
Joseph Mulherin
I called Shopsmith this morning and they looked up my account and found out I purchased the blade in July. And they are sending me a new blade to replace. Also ordered another 1/4" blade.
