WE MOVED...
? about hanging a heavy shelf
bj
I made a built up solid oak crown molding shelf for someone to rest on top of an entertainment center. They recently got rid of the entertainment center and would now like the shelf mounted on the wall. The shelf is 72" long and about 16" deep and weighs probably around 70lbs. They would like to use it for a flat screen TV but want to avoid using brackets if possible. I have a cleat made for the back but am unsure if that will be able to support the weight of the shelf + the television. Anyone have any ideas how I can anchor this beast onto the wall without using brackets underneath????
Re: ? about hanging a heavy shelf
Dick Coers
I'd say that 16" depth is your real enemy. That's a lot to cantilever, and a ton of weight. I'd suggest some type of corbel to them first. If they insist on no bracket, make sure your insurance is up to date!
Agree with Dick. That much of a shelf w/o a corbel is a real problem. You are talking about some serious torque.
Can you talk them into a set of corbels? Don't get me wrong - my shop wall cabinets are hung with French cleats. I've used "Z" clips to hang upper cabinets also - but in both instances -the lower portion is resting on the wall.
Engineering
I was describing a method for this type of shelf support with Moses Yoder recently. (A search should turn up that thread.) Anyhow, the concept is to put metal rods into the wall and mount the shelf onto the rods. As with any engineering problem, you need to decide how much weight you're supporting to figure the size of the rods. I've hung 12" shelves on 16" stud centers using 1/2" rods. For something as large as your shelves, you might consider heavier rods. The trick is to bore holes directly into and through the wall studs, perpendicular to the plane of the wall. Make corresponding holes in your shelves.
It's doable. I've done it. You're responsible for your own engineering though.
Ellis Walentine, Host
why would the cleat not work?
Bill Tindall
Presuming the shelf is fairly long it will have at least three studs behind it. A few #10 or #12 screws into the studs will hold the weight.
Or as Ellis suggested I have mounted mantels to a wall with pins into the studs, but that was before I found a source of metal cleats.
Joseph Mulherin
Question? what is the thickness od the shelf?...is it like a mantle...about 3" thick or just a couple boards glued together? I agree with Ellis that you should install at least three stud bolts, but I would drill the holes a little bit larger and use epoxy to hold them both in the shelf rear and the wall studs. 12" threaded rods would be my choice...something to give the epoxy more room to adnere to.... or some rebar would work too.
bj
The shelf is about 6-7" thick. I built up 4 1/2" crown with some other molding plus the 3/4" thickness of the oak board on top of the shelf. I will try to attatch a picture this weekend so you can see what I am talking about.
JMOHNIKE
Forget it, and find another project. It sounds as if you are trying to mount a shelf in a manner that was never intended, nor designed into the shelf. If the shelf fails and the TV is damaged or someone is injured, you could find yourself paying for a TV that you can not watch, or paying for some ones medical bills. You/they might consider a commercial wall mount bracket for the TV and then redesigne the shelf to go around it and hide it as much as possible so that the shelf is not supporting the TV. Also a 16" deep shelf, depending how high it is mounted to the wall could be a real head banger.
Just my 2 cents worth.
Joseph Mulherin
He is correct in his interpretation of your project. Hang the TV using the manufactured wall mounting fixture
and install the shelf as I said earlier. 6-7" of solid wood is a bad thing to be hanging on the wall anyway.
Buy the manufactured fixture and just install it that way.
You say the shelf is 6 1/2" thick. What I would do is mill some slots in the back of it to accept some 1/4" thick plates. the plated would have key holes in them to accept the heads of 4" by 1/2" lag bolts. On a 6' long shelf I would locate all the studs in the wall behind it and drive a lag into each one. Install a corresponding plate in the back of the shelf as near the top edge as you can. Install each plate with about four No 14 counter sunk screws about 2" long. Hang the shelf over the four bolts.
Since the shelf is as thick as it is, the forces would be trying to extract the bolts form the wall and pull the screws out of the back of the self. Similar to using a hammer to pull a nail. It would probably also work to use rebar about 5/8" in diameter epoxied into the shelf and the wall studs, but that would make it difficult to remove the shelf later. The bolts make it relatively easy. Either method would be a lot more reliable if the shelf had some corbels or brackets below it or cable or chains above it.
Before I put this into service I would want to make a mock up and hang my fat a$$ off it as a test.
Having said all that, I agree with the others who thing the smart move might be to use a manufactured bracket to mount the TV and not take the risk.
Another vote for TV bracket...
Bill Howatt
with the shelf looking like it is holding the TV up.
Bill
John b. chicago burbs
In Fine Woodworking #32, Ian Kirby built a torsion box shelf and hung it on a wall using a hidden cleat. Mr Kirby then sat on the shelf. I am sure that he weighs more than a flat screen TV. Having said that my lumber rack consists of 3/4 "x16" EMT placed in a hole drilled into 2x4" studs on about 48" center and they are pretty well loaded. John b.
Joseph Mulherin
BJl
Harbor Freight has the TV wall mounts on sale right now at $39.99....regularly $79.99.
more on cleats
Bill Tindall
Over on the hand tool side there is a post on museum picture frames. These several hundred pound frames are held to wall with cleats, it was reported.
Bob Hackett
If this shelf was designed to work while being supported by something else (the entertainment center) then I`d suggest you stay within the original design restrictions. The shelf should be either supported from below or by braces or corbels from from above by some other manner in order to be safe and yet cost effective from an installation point of view.
If the customer absolutely HAS to have it look like it`s self supporting then that comes under the heading of illusion and magic costs money. I have installed things that look like they`re floating but only pulled it off at a huge increase in the installation cost because it required me to tear down and rebuild the wall to include all new bracing and support structure required to transfer that load and still look like there was nothing there. I`m talking about doubled and sometimes tripled studs with thru bolts and plenty of screws and glue which allowed me to attach (many times over engineered) metal brackets and custom hardware. Anything else opens you to liability.
Once you explain this to the customer those corbels or braces begin to look far more attractive.
