Finally Finished
Greg Muller
Finally was able to finish a project I have been working on for almost a year. This is a library type stand only converted to hold a large slab of wood. The wood on top is a 600 year old slice of black oak that I sanded and sprayed clear. The stand is also oak. I used mortise and tenon joints for the legs and cross members and a sliding dovetail to connect the top. My big concern was weight as the slice of wood weighes almost 40 lbs so I could not use the flip out stand that the original plan called for. After posting the problem here the sliding dovetail was recommanded not only for the weight problem but also wood movement, which I had not considered. The finish is a wipe on stain and a water based laquer that I sprayed useing the Earlex 5500 for the first time. Very easy to use after a little experimenting.
For me this was the first time I used a M&T joint or a sliding dovetail so there was a learning curve but it was a great learning experience. I did a lot of mockup before along the way, much more then I ever had before, which was very helpfull. I would encourage anyone who is thinking about trying new techniques to plunge ahead as I now feel very confident about tackling the next project. I also want to thank all of the people who answered my many questions along the way as you helped me immensely.
