Need a definition. What is proper name?
Gary Smyth
I confess I'm trying to get a value for this item. It is NOT for sale, this is for my records only. It is a Lufkin 40" mapping "something", as it is calibrated to 50,000:1 USGS maps. Boxed as you can see. It is stainless, approximately 1/4" thick on the back edge and beveled to a knife edge near the front at the markings. The box has a U.S.E.D. plate (Engineering Department). It is a hefty 3 1/2 lbs. out of the box. I've searched the terms "Lufkin", "rule", "ruler", "scale", "drafting", "mapping", "surveying" "engineering", "stainless", alone and in various combinations and come up empty. I do not have a Lufkin catalog, or rather no longer can locate my 1940's Lufkin catalog, nor can I find a modern equivalent in current surveying catalogs.
Can any of you tool slueths give me the true name for this? If you also happen to run across a model number, date, and/or old value please feel free to provide your information. I'll follow up.
Re: Need a definition. What is proper name?
Moses Yoder
Moses Yoder
It has a scale on it, as defined by dictionary.com "a series of marks laid down at determinate distances, as along a line, for purposes of measurement or computation: "
The proper word for it according to dictionary .com is RULER "Also, rule. a strip of wood, metal, or other material having a straight edge and usually marked off in inches or centimeters, used for drawing lines, measuring, etc."
So far as a value, the value is very arbitrary. If it were to go to auction and only have one interested bidder the value might be $3. If there are 2 interested bidders, it might be $3000. I believe I have an old Lufkin catalog, but I doubt this piece is in it; I will probably look just to make sure. It was probably specially made for map making. If I had to guess, with the nice box and everything I would put the value at $500. If I had that piece I would definitely display it at the county fair in the antique tools division.
steve mackay
I'm a BIT of a Lufkin collector. Never seen that one before. Let alone with the case. From sales I've seen I'd think it might START around 250. If you started a feeding frenzy I'm sure it would go over 400. Sure is a keeper and I'm green !
Maybe
What you have is called an "Architect's Ruler" as was used to do large site plans where a scale of 50,000:1 was needed to lay out the entire site. Used in conjunction with the T-Square and drafting table. They came in a number of scales and could match up with USGS topo maps. Most county-sized USGS topo maps were rendered in the same 1:50,000 scale so this may further help the definition as an assist in using convenient published topo maps for land use and site planning. For actual structures, they would use a smaller reference (1":50") but with the same ruler.
Nice artifact but rendered obsolete by CAD.
Do NOT, however, bet the ranch on this. :D
Straight Edge *LINK*
Henry Higginbotham
Generically, anyway. What is the measurement (in, say, inches) between the cardinal marks on the edge? A scale of 1:50,000 is useful for a map covering several miles in each direction, and of interest to civil engineers but not architects.
Most engineering and architectural offices I've been around had at least one such straight edge, usually in the print room.
This sounds like the sort of thing Rob Lee might be able to name properly.
Here's a link to a Starrett straight edge, beveled on one edge and graduated in inches:
Starrett Straight Edge
Re: Maybe
Ron Jones
You may very well be correct Mark. However, I believe it is referred to as a "civil engineers rule or scale".
As I understand it a straightedge
Gary Smyth
has no markings. It is not flexible and may or may not have a knife edge and may or may not have a cork "lift" to keep ink from bleeding underneath, but no length markings -- by description a true t-square is the same with the difference of a perpendicular piece and a flexible steel blade. It also does not have distance markings. These tools are not to measure but to draw lines.
Re: As I understand it a straightedge
Henry Higginbotham
Hmmmm. I guess you can take that up with Starrett. ;)
I agree that the item you showed us has markings that indicate its intended use as a scale. But I'm holding to the notion of something of this heft and cross-section being essentially a straight edge. A scale really has no need to be precisely straight, as slight deviations likely won't make a difference that you could see even with a magnifier (cosines and all that, ya know?).
Anyway, looks like a nice item, whatever you want to call it. Hope you find some valuation info.
You are both right - sorta.
Ray Thompson - Middletown, IN
It's generally referred to as an engineering scale which comes in many different scale markings. When it is a large scale such as 50,000:1 it's generally used by civil engineers. When it's 1/4:1 or 1/2:1 it's generally used by architects. Same use different scale markings.
Ray
Steve Strickland
Re: Another One...
Steve Strickland
That's very cool. Here's one that has an official published name for ya'll to figure out:
Printer/type setter ?
can you provide more info
Ian (in Sydney, Australia)
You have what I'd call either a "scale" or a graduated steel "rule"
the difference is
a "scale" is used for measuring and typically the measuring edge tapers to minimise parralax error -- a scale should never be used for drawing lines, as doing so can damage the edge
a "rule" is rarely tapered and can be used for drawing lines.
can you tell us a bit more about the tool, is it exactly 40 inches long?
are there 50 or 100 graduations per inch? -- the graduations look like decimal inches
as others have mentioned, probably an engineer's tool
nd is it exactly 40" long or a little bit shorter?
40" is an unusual length, especially given that a metre is 39.4 inches
Couple more
Gary Smyth
There are 50 marks to the inch. Engraved on the center of the item is the word "Scale 50". It is 42" (1066.8mm) long and 2.25", (57.3mm) wide. I guess I could call it an engineer's scale and leave it at that.
Ken Kimura
It's a mapping scale. Probably moving into the obsolete arena with computer programing. 1 : 50,000 scale is a large area map showing less detail than a 7.5 minute quad sheet which is at a 1 : 24,000 scale. Before computer mapping programs, it was useful for scaling and laying out large public works projects - roads, property acquisition etc.
Re: Couple more
Hi Gary
"Scale 50" referes to the 50 graduations per inch, if they are inches !
"Scale 100" would mean 100 graduations per inch
What has me intreaged is the rule's measurement length -- 40" which is almost exactly 1 metre
Somewhere I have a scale graduated so that when you use it to measure an imperial plan of at a particular scale (civil engineering plans used to be dimensioned in decimal feet, not feet and inches) to metric
The scale you have could have a similar use, in part the key will be how long each "inch" is -- 25.4mm or something a tad less?
Given the rule's length, I'm going to suggest "Railway Rule" which before squared paper and pre CAD would have been teamed with "Railway curves" when drawing plans for railways and highways
Steve Strickland
Re: Answer *LINK*
Steve Strickland
This one is called a Sparse Ruler because it has the fewest marks necessary to measure all integer distances up to the ruler length.
Sparse Rulers and their variants have been the subject of considerable effort during the 20th century. No algorithmic solution has ever been found for them.
An Unsolved Combinatoric Puzzle
