A55 Smoothing Plane
Concrete Sealer
Concrete Sealer
Concrete Sealer
Kelly M. Robison
Hi All, Not really a wood working question; But, I just had a new work shop built [24 ft X 24 ft]. It has a new concrete floor and somebody recommended that I put a sealer on it. Has anyone had any experience with putting a sealer on a new floor and can recommend what type to use. I went on Google and found about a hundred and now I'm confused. Now that I have a new floor with nothing on it, I know that now is the time to either put down a paint or sealer on it. Help, Please.
Kelly in Port Orchard
Re: Concrete Sealer
Concrete Sealer ....yes
Bill Tindall
I have sealed any floor I have poured. It makes the floor easier to sweep. Use what ever the concrete supplier recommends. However, (tip from brother-in-law the lighting engineer) for a shop where lighting is a challenge, painting the floor a light color will greatly improve illumination. Some of the light that uselessly reaches the floor will be reflected back to the work area.
Re: Concrete Sealer
Re: Concrete Sealer
FredD
The concrete would have been best sealed as soon as it was firm enough to walk on.
For now ,tape a piece of Saran Wrap or similar flexible plastic roughly in the center of the slab and when it stops getting beads of moisture under it because the Concrete is still flashing water, paint the floor with a Epoxy paint , generally a two part mix, you will be glad you did.
No dusting and much smoother.
FredD
Re: Concrete Sealer
Re: Concrete Sealer
Jim Hager
I have to chime in because you have been advised to paint your floor and in my opinion that is the absolutely worst thing you can do. It will peel. My current shop floor was troweled very well then before moving in the equipment a couple months later after construction I mopped on a concrete floor sealer that looks similar to a floor wax. It is available by most suppliers to institution cleaning supplies. Mine was "butchers" brand but just about any of them will work just fine. Check with you local school or janitorial supply house to find this kind of product. My floor is still nice and slick and easy to sweep after 8 years without additiional applications of sealer. We used it also at the school where I taught shop and applied a new coat every summer just to make things look better. We also had "machine safety zones" painted on the floor underneath the sealer and they always peeled and began looking bad after only 1 year. I strongly advise against paint.
Re: Concrete Sealer
Paint
I've seen concrete floors painted with oil-base paint. The oil reacts with the lime in a process call saponification, and they peel as the film breaks down. Waterbased stuff also peels, especially where i gets degraded by oil or solvents. Epoxy garage floor coatings are a very different story. Properly done, they'll look like new after years of tires, salt, oils, etm.
Re: Concrete Sealer
That makes sense
Bill Tindall
Both oil and water based paint will be attacked by anything caustic. I hadn't ever considered this problem. On the other hand I know floors that have been successfully painted, so they must have used epoxy.
Re: Concrete Sealer
Re: Concrete Sealer
Paul Blackwell
I just moved into a new home, and sealed the garage floor and the area in the basement that will become my shop. I used a product from Sherwin-Williams called H&R concrete and masonry waterproofing sealer, acrylic based. It's easy to apply. I bought an 18" roller and coverage on nicely finished concrete is about 400 sq. ft. per gallon. I just splashed a small amount on the floor and rolled it in a small area, and repeated the process. No odor, and water cleanup. It dries quickly, and water beads up like a wax job. Easy to sweep up. I can't speak for the durability, since I just applied it a couple of weeks ago. Cost is about $25 per gallon.
Re: Concrete Sealer
Re: Concrete Sealer
FredD
Depends on what you know , note I advised Epoxy paint, our Garage has been paint with Porter-Paints epoxy formulated for concrete and it looks a hell of a lot better then concrete with a transparent sealer over it.
Painted my me in 1997 and still holds the shine , no chipping or peeling.
As I stated before , you need to have the Concrete as dry as it will ever be before you paint it and that's not something easily rushed.
Paint over a floor still flashing water and you always be sorry and because many are not knowledgeable about the process, they blame the Paint.
FredD
Re: Concrete Sealer
Re: Concrete Sealer
Tony - Memphis
When my shop was built 13 years ago, I just sealed it with regular old Thompson's water seal. Nothing exciting. It seems to keep things I drip/drop/spill from soaking in. I sprayed it with a tank sprayer.
Tony
Re: Concrete Sealer
Re: I did both
When my shop floor was poured about 7 years ago, the finisher had a 5 gallon pail of sealer / curing material he sold me at about a half price discount (don't remember the brand). I applied it as soon as the cement could be walked on and let it cure. It did leave a shiny surface. After finishing the shop, we cleaned the floor and applied the Rustoleum epoxy garage floor paint. It held up extremely well considering I have almost all my equipment on mobile bases and we move the equipment out of the way and do automotive work on my son's and grandson's vehicles when necessary. The floor has seen a lot of brake fluid, motor oil, antifreeze, transmission fluid and grease during these episodes. None of these has left a lasting stain. The 20" Yorkcraft planer has left a few marks due to something being caught under the wheels, and my Unisaw also has left a few marks -same cause. I do need to re-coat a large section as I spilled a quart of shellac on the floor and it left quite a non-removable stain, also need to remove glue and re-coat areas where about a pint of Titebond 3 dripped in various places during glue-ups :>), seems there is never enough time to be careful when making a major glue-up. All in all I don't believe I would do anything different to the floor. It has been pretty slip resistant, easy to clean and looked (IMHO) good for about 7 years now.
Re: Concrete Sealer
Jason Roehl in Lafayette, IN
Removing shellac...
Larry,
That shellac should come up with just a little effort. Mix up some ammonia and water in a fairly strong solution, pour it on the stain leaving a puddle just larger than the stain and let it sit for a few minutes (proper ventilation and all that). Then mop it up. Repeat if necessary.
Or, if you want to get good and high/drunk, you could do the same thing only substitute denatured alcohol for the ammonia solution, but the alcohol may attack the epoxy to some extent.
Jason
Re: Concrete Sealer
Re: Concrete Sealer
Ken Garlock, Collin County Texas
Hi Kelly. When we built back in 2002, the painting contractor put down two coats of SHERWIN WILLIAMS TWO PART EPOXY on all our garage floors, and my shop. IN all cases, 3 car size, 2 car size, and shop, the SHERWIN WILLIAMS Epoxy has held up great, no pealing what so ever. In the shop, I have some small chipped concrete spots from heavy things digging in, but otherwise the floor epoxy is in nearly new condition.
Did I mention that it is SHERWIN WILLIAMS two part epoxy?
Sherwin Williams makes quality products. Once overfilled my car battery and the over flow of acid and water only discolored the epoxy.
Happy saw dust,
Ken
