Drawer slips
Bill Tindall
Drawer slips are a feature of every English drawer I have ever seen in antique stores. English drawers tend to be made from thinner stock than American drawers. The slip provides three functions. It provides additional bearing surface for a drawer with thin sides. This function could be useful on a large drawer. The slip provides the groove into which the drawer bottom is "slipped", without weakening the thin drawer side with this groove. And finally, the slip makes an easy task of aligning the grooves for the drawer bottom. Additionally, the "slipped" drawer looks attractive from the inside.
There are all sorts of variations on the slip. What is shown in the picture is an example that is easy to make and install. I make the slip from scraps of wood such as the piece that has not yet been cut to size shown in the center of Picture 1. Slips are made about 1/2" thick. If the scrap is wide enough two slips can be cut from one piece of wood, which is efficient, is in the case shown.
In Picture 1 we can see the notch that is removed from the back of the slip. Its depth is made so that the top of the groove aligns with the bottom of the drawer back, allowing the drawer bottom to be slipped in from the back of the drawer. The slip groove is aligned with the groove in the drawer front by employing a piece of wood the exact thickness that the groove is wide, as seen in Pictures 1 and 2.
After fitting the slip is glued in place. A rub joint is sufficient if the mating of the slip and drawer side is precise. If not, clamp for a few minutes.
The slip width is sized so that its edge falls below the fitted drawer bottom. What ever part of the slip sticks past the drawer side bottom is planed off so that the bottom of the slip and the bottom of the drawer are even.
I didn't invent any of these techniques. Rather, they have been adapted from other's work and suggestions, as well as studying English furniture.
