Removing Glue from strap clamps???
I have several band or strap clamps and they occasionally get a workout. They have gotten glue on them, making adjusting them difficult. Clearly it would have been a good idea to keep the glue off, but in the heat of the moment it did not seem to be a priority.
Anybody got a way to remove PVA (mostly the yellow stuff) from the nylon straps?
Re: Removing Glue from strap clamps???
Vinegar works well at softening/attacking yellow glue. I don't know what it will do to your nylon though. Nylon is a polyamide, so the bonds should be strong enough to resist the vinegar. I'd try some vinegar at a strap end.
The vinegar will take some time to soften the glue (hours). I usually put a dampened paper towel on the glue surface. I have used vinegar primarily on wood surfaces.
Another thought is dry ice (or wet ice). I've used ice to cause glue to get brittle and then cracked or flaked the glue off. Try ice as a quick test.
Re: Easy
Bill Tindall
The laundry process removes yellow glue from my pants. So....you could put them in a bag so they wouldn't clunk and add to your shorts (well maybe pants) in the washer. Or replicate the conditions in a bucket. Hot water turns white/yellow glue to mush which is then easily removed from anything- fabric, glue bottles, joints, spreaders, etc. Not sure if detergent adds any benefit. The water needs to be hot.
One should launder band clamps as needed to keep them looking bright and fresh. Smudgy band clamps don't look attractive in posted shop pictures.
Depends on which PVA
Dick Coers
I actually glued a patch on a pair of work jeans with Titebond 3 and it has not released after about 10 washings. Not very skin friendly though! I think the vinegar soak is the best option.
Vinegar, dish soap and HOT water.....
Worked in about an hour. Some scraping and scrubbing and resoaking and the straps are MUCH better. It was like archeology. I must have used at least four kinds of glue. Titebond 1 and III and Elmers and Gorilla glue. The various PVAs were affected in different fashions and most of them came out pretty well, but the Gorilla glue was pretty much unaffected. I doubt I will be using that stuff again.
Thanks for the help.
