Ditto
On Ellis' suggestion. After sanding, I would blot on a 1# cut, allow to dry for several hours. Then sand lightly, blow off the dust, and blot on a coat 2# cut (rather than 2 applications of 1#). Allow to dry well (4-8 hours depending on "climate") The finish you use for a top coat should be dictated by use. For hand application, I like to use Waterlox gloss for vertical surfaces, but it won't stand up to working top surface (kitchen or coffee table) use. For a surface that will "carry" items, I'd go to the polys. I've migrated away from most of the oil finishes, currently using General's Clear Poly waterborne with cross-linker added. It is, however, really designed for spray application; haven't tried to hand-apply the stuff.
hth
