mitred corners on a solid walnut cabinet
peter bunnett
I have to make a solid walnut cabinet 16inches deep . Planning to cut a 45 on the table saw then clean it up witha straight router bit on the same angle. Is there a betterplan . Thanks pete
peter bunnett
Clean Up? Router Bit?
Don't understand your question. What will you be "cleaning up" and what does the router do?
If you're cutting a mitered joint on the saw, you should be using an appropriate blade for a clean cut.
Re: mitred corners on a solid walnut cabinet
Jesse Cloud
A miter joint isn't a strong load bearing joint. I would use dovetails. If you don't like the look of dts, you can put some trim over the joinery and miter that.
If you can hand cut dovetails, you can miter the shoulder of the show face. Chris Schwartz had an article on that in Pop Wood a while back.
Bruce, a MN Galoot
If you can do it, use full-blind dovetails. They're very strong and look like a mitered joint. If not, then through dovetails.
If you REALLY want just a mitered joint, I'd strongly advise you to use splines parallel to the joint.
A good, sharp blade will make the cut you want. Just be sure to make a test cut first to be darn sure the finished product turns out to be square.
Mitered case joinery
Hi Pete,
Your question isn't perfectly clear to me, but if you're wondering the best way to make mitered case joints, I say to cut the miters on the tablesaw using a good carbide-tipped blade for a clean cut, as Mark suggests. Generally, more teeth will yield a better cut.
As Jesse said, the miters themselves aren't the strongest joints, so I always reinforce them with either biscuits or splines, inserted near the inside edge of the miter. Cleaning up with a router shouldn't be necessary if you've cut the miters accurately.
If you need more information, don't hesitate to ask.
Ellis Walentine, Host
Bill Tindall
agree with the dovetails, or splines if mitered.
Jim Hoeller
Are the miters along the grain or across the grain? If along the grain, I would consider the joint as strong as any edge glue joint and not need reinforcement.
Good point
Re: Good point
peter bunnett
The mitred corners I'm referring to are endgrain 16 to 18 inches deep with at least one row of biscuits in 1 inch thick stock. My concern is not with strength here but a perfect mitre with no gapping for aesthetic reasons. That's why I'm thinking going over it with a straight bit ona 45 degee angle would ensure a cleaner joint? Thanks to all.PB
Carbide saw blade should be good enough
John in NM
The hard part of such joints is getting right on 45 degrees and then clamping it tight enough for a good looking joint. If you can do those two the cut right off the saw will work fine.
I tend to use splines rather than biscuits as you can make it fit tight enough to make clamping easier. The few times I tried this with biscuits there was quite a bit of movement from the biscuit fitting loose in the slot.
Re: Good point
Bob Lang
The key will be perfect stock and a perfect cut. Or as close as you can come. I would make some test cuts, it all depends on the type of saw you have to cut it. If I had to clean up the saw cuts with a router, I'd be thinking about a big 45 degree bit, rather than trying to tilt a straight bit at the perfect angle and guide it straight across the board. Shooting the angle with a hand plane might be a safer alternative.
Plan B might be to rabbet the two pieces leaving a minimal amount of the end of the rabbet exposed, then adding mitered edging to the front.
Bob Lang
Re: Good point
I too was wondering why a long grain miter wouldn't be adequate. Butt or end grain not so much. I would do it on the TS with a good cross cut blade and spline with the grain running the the same orientation as the carcase.
If you really want to use a router this might be an excellent application for a lock miter bit. A stronger joint with good alignment and you get to buy a new bit.
I am certain I could cut the joint on the TS and equally certain I could never "clean" it up with a straight bit in a hand held router.
Re: Good point
AZ in Colorado Springs
Make some clamping cauls that you can lay along the outside of the corner of the casework, with a cavity shaped so that it will pinch the joint a bit and make for a tight glue line.
I'm thinking maybe a 4x4 (or some hefty piece of stock that will not flex along its own length, or you'll need to place more clamps closer together) an inch or two longer than the depth of the cabinet. You cut a deep rabbet, 1" or 1-1/4" wide and deep, along the length of the 4x4. The sides of the rabbet are not 90 degrees, but about 92 degrees, so the sides angle away from each other by a few degrees. Then, use your table saw to cut a shallow cavity in the center of this approximately 96 degree angle.
As you're gluing up the cabinet, lay these cauls along the corners, and as you tighten the clamps on them, the inside edges of the rabbets will close the joint along the edge of the miter, giving you a clean joint line.
Re: Good point
FredD
I have done many a Lock mitre router bit assembly, always on long grain.
If you contemplate doing it on cross grain a inch thick , you will be sorry.
FredD
Re: Good point
Apparently Fred has experience with this and I do not. Listen to him or be prepared to be disappointed. I have never cut a lock miter joint and don't own the bit for it. Don't even know if they make one for inch thick stock. If you go this route, practice on some similar stock you can afford to trash.
As an aside I made some night stands for my son and DIL that had an end grain miter in them. I used a Kehoe jig I had that had been lurking in the shop unused for about ten years and cut splines through the miter and then sanded them flush. That has been about a year and they are holding up well. You can search Youtube for videos of the jig in action. Worked better than I expected.
