Re: soldering question
TomD
You can't really successfully remove the oxide from aluminum by mechanical means. You can probably clean it, but the oxidation process is instant. With TIG, that would be OK because it uses the alternating current to blast oxide off the surface in a continuous cleaning process. SS brushes may contaminate Al surfaces and degrade results when fluxes are subsequently used.
(As an aside, be careful dreaming up processes. One frightening post I read years ago, concerned a guy who had degreased metal with brake cleaner, then TIG welded it. Apparently, the brake cleaner in the presence of Argon shield gas and heat gives off phosgene gas, and he was permanently injured).
A good place to find info on aluminum is over on Tinmantech. Back in WWII, the US did a lot of very clever things with aluminum. Their aero gas tanks were studies in using all manner of available and expedient processes. Depending on the application they soldered, brazed, and welded aluminum, and used pretty much every welding process a modern worker has heard of on Al, as well as some he probably hasn't. TM sells solder and braze for Al, that operate at high temps below and above the 840 F crossover point. This is stuff most people do not even know exists. Unfortunately they aren't telling what is in this stuff, and don't offer the MSDS for it though I would be concerned it is harmful at some level, if I were using it. Maybe the MSDS is available elsewhere.
http://www.tinmantech.com/html/soldering.php
