Re: Chisell Storage on Walls
TomD
Wilbur, I have concrete floors, so while I use those Odate style racks for lots of tools, I don't use them for my better chisels. If I had wood floors I probably would since they are very convenient.
Anyway...
I make these "fitted" racks in maple. Just drill a hole in a piece of wood to the minor diameter of the ferule, then enlarge with a reamer. You can see the reamer I use in one of the racks. Then once the hole is the right size, for all the chisels cut off the front of the strip to expose the holes for a front entry.
It is best to start with the small chisels since they will fit down into the rack with the holes closed off. Do the final fitting on the larger chisels after exposing the front of the holes.
Very quick project, and really gets them organized. On the larger rack I have 4 rows of chisels and I put them too close together. Sometimes when removing a lower chisel I take a scratch on an upper one. I should have left an extra inch or two.
