How to remove cup in a board
Tim Bergmann
I have a 1" x 20" x 14' board that sucked in moisture and cupped rather badly. Any tips on how I can get it flat again?
Tim Bergmann
need more data
Bill Tindall
How much is it cupped?
Exactly what are the circumstances of it cupping? Wide lumber can sit around for ever and not cup even thought he humidity changes. What details caused this board to change?
How do you intend to use it?
Lumber that cups during initial drying can only be un-supped by mashing it flat and running it back through the kiln. The initial wet steam will soften the wood and relax it into flatness. On the other hand lumber that has one side exposed to wetness or dryness will often flatten itself if exposed uniformly on both sides. so the moisture level in the board becomes uniform again.
Ideally the way the lumber will be used will allow the board to be pulled flat and held that way, for example in a table top fastened to a frame.
Re: How to remove cup in a board
Dick Coers
Are you saying that is was once flat in your possession? A cupped board can be a condition of where it came from the tree. Get too close to the center, and there is no way it will be dead flat. Get too close to crotch figure and the same is true. Finding a dead flat 20" board would mean it came from a huge and rare log. I never appreciated really nice wood until I started milling my own. Finding that flat clear board can be a real treasure hunt sometimes.
steve mackay
If it were THIS GI . . . AND I spent money on it . . . AND I really wanted to use it WHOLE . . . AND I figured I'd have enough left afterwords . . . I'd haul it over to my tame millshop and have 'em run it through their big TimeSaver sanding machine and get 'er trued up. But you didn't say what flavor it is or the depth of the cup. If it's oak (or above) I'd spend the ten bucks. If it's pine I'd just strip it out.
Keith Newton
You can lay it cup side down, and put it in the Sun. As the convex side warms up, it will give up moisture on that face only, if air can't get to the other face. Some will advise laying it in damp grass, but I don't like to add moisture, unless I knew for certain that the cupping was caused by over drying the concave face.
In winter, I have put wood on a bench top, with tarp over, making a tent, with a space heater blowing under one end, allowing some to escape from the other.
George Colonel's Workshop-Havertown PA
Hello Tim,
I've put a kerf thru the length of the board and pressed it flat. Of course the application will govern the acceptability of that method, which is quick and easy.
George
FredD
It's unlikely running the board though a wide belt sander would do anything but remove stock evenly and once it cleared the sander the cup would still be there.
FredD
steve mackay
If he runs it through without lowering the top with a lot of preasure it'll take off the high parts. Then keep flipping it. Like I said, I'd do it for a peice I paid a lot for. I tried "manipulating" with moisture and preasure but i can't afford for it to cup again. And to often it will. It'd probably be in Iraq and I'd have angry GIs.
