bench wheels flip style
Carol Reed, Strawberry, AZ
Want to see some pix/plans for wheels on a bench that flip in or out of use. Whatcha got?
Re: bench wheels flip style
Galen Vetterick
My work "table" ended up 34"w x 96" L X 39" high so neither of these ideas seemed too helpful. Considered swival trailer jack but ended up just making it so it could be knock down just to move.
http://lumberjocks.com/projects/12527
one version I looked at but needs a lift lever for all the weight I had.
http://www.newyankee.com/getproduct.php?0207
This is the one they say Norm built and found only a picture and his is to light for me too. His flip down blocks are lighter than the heavy frame of the one above.
You did not say how large/heavy of bench and material it is made of or is it not yet fabricated.
Just ideas.
Pat Evans
Carol: don't know if something like this would work for you, but it works well for my router table. Bottom shelf with casters underneath floats within the legs. Not shown in the pic, but I have hinged spacers on each end between the bottom rail and the shelf. With the spacers down, between the shelf and rail, the legs are off the ground and the table is portable. I can lift each end and flip the spacers up making the legs sit on the floor.
Jesse Cloud
Warning: stealth gloat to follow...
I went to the Woodworking in America show last weekend. There were ten classrooms, each with a bench. As I recall, there were casters on a board the width of the bench, hinged to the legs. That assembly was on both ends. So they basically lifted up one end, kicked the caster board into/out of place and the benches were mobile. These were full sized workbenches, mostly Roubo style.
Dick Mahany
Here is one possibility. I made these for my 350 lb+ bench. Ugly, but work great.
Higher resolution photos can be seen here:
https://picasaweb.google.com/dmshopshots
