We value your privacy.
I'm attaching 1/2" high-quality MDF false fronts to 1/2" plywood drawers. (These are for use in an upstairs "bonus room." The largest front is 13" x 27". Does this call for confirmat screws? Should I also use glue between the ply and the MDF?
PS - please don't try to persuade me out of the MDF. Long story - that train's already left the station. ;-)
There are a number of useful tips that i can offer here. I don't know why you are using half inch. I usually use 3/4", which give a bit more thread bite.
Those screws should be good, if the pull screws go all the way through to the inside of the box.
There are a number of tricks for getting the fronts aligned perfectly after the cabinets are set.
But, if you have a problem with the screw bite in MDF, I like to
Take it off, then saturate the screw crater with thin cyanoacrylate glue. It will soak out into the surrounding fiber, forming a solid, Locked in plug, which may need a new pilot hole to get the screw into, but you will know it is solid after you do.
