Stall mat flooring?
Stall mat flooring?
Stall mat flooring?
Pat Evans
Has anyone ever used horse stall mats over a concrete shop floor? At my age (and weight) the feet, knees, and back all hurt after too many hours in the shop. The stall mats are heavy enough to lay flat and I would think add cushing. However, I'm not sure if they would provide enough cushing to warrant the expense. They ain't cheap.
Re: Stall mat flooring?
Bob Hackett
They are well worth it and I like them better than the mats I got from the deck of fishing boats that I was using before I came across them. They are far cheaper,clean up easier and help keep my feet warmer during the Maine winters.
The only drawback I can see is that they are a little more slippery when wet than the deck mats I was using(the deck mats have through holes) but not by much. As long as I keep the snow I drag in to a minimum everything`s fine in Shopville. :)
I had stall mats in my old horse trailer. They worked well there. They were quite heavy though - so I'd be reluctant to use them in a shop.
I have a couple of shop mats that work quite well. I also lucked into a solvent resistant floor mat from my old work place. It has the advantage of being cushioned as well as being resistant to stains and finishes.
Your choice. I think the shop mats and anti-fatigue mats are a little easier on the feet and "softer" than the stall mats.
I have one in front of my lathe I got from Wood Craft. Works well. A local service station I deal with has some that fit together on the ends like puzzle pieces and are much softer than the one I have. I asked about them and I believe they told me they don't know where to get them anymore. They would be great. I will have to double check to see if they know where to get them.
Bob Hackett
The ones that can be expanded by linking them together were what I had from the fishing boats. You might want to look for them at the places that supply commercial vessels. I can tell you that they are expensive new,that`s why I snapped up the used ones.
They were softer than the horse stall mats but I didn`t like trying to clean the wood chips out of all those holes they were riddled with. I found them to be a real PITA to keep clean. My buddy who tried using them in his machine shop had the same complaint.
One advantage the fishing mats did have was that they could be linked to a tapered edge to reduce the tripping factor and make it easier to roll things onto and over them.
Carol Reed, Strawberry, AZ
Goggle interlocking rubber floor mats. You will get a zillion hits. They are used in weight rooms, day care centers, pet grooming salons, and gyms. Goodness only knows how many other places.
I have a bunch and like them a lot. I bought them a package or two at a time over the years and now have a whole floor's worth. Get the edges, too. Makes sweeping up MUCH easier. LOL!
Craig Daymon
Actually, I thought they were pretty cheap for what you got. I had 2 in my basement shop in PA. One at the lathe. They were 4'x8' in size, quite heavy and provided a very good surface for standing on for extended periods. I think they were the right firmness.
I can't say I'd floor the entire shop in them and I'd probably consider cutting some in half to use for smaller areas.
Pat Evans
Carol, is it easy to roll equipment on casters over the rubber mats? My shop is small and lots of equipment is portable. The rubber mats I looked up were high density rubber and I'm not sure they are dense enough for casters to roll on. The stall mats are extremely dense. Duh... they have to withstand horse hooves.
Heavy stuff, no. Its too light. But it is easy to pick it up, move whatever, and then snap in back in place. All my stuff is on wheels, too.
frank ashmore
Make a pair of shop shoe's .Just cut out the shape of the bottom of your shoe's from the flooring mat and glue them on the bottoms of your shoes.This way your whole shop is cushioned and it only cost 1 sq.ft. of flooring.JUST KIDDING but I wonder????
Or just wear a pair of Dawgs. Same thing, but no glue up. :)
paul woolson
I've got wall-to-wall horse stall mats in my shop. LOVE THEM!!!!! They're very heavy so they don't move at all (there is about a 2" gap on one wall ). The heaviness is horrible when installing them. Hire some high school wrestlers or something if you end up doing it.
the mats are very easy on the knees/feet. But the main advantage I've found is that I can (and do) drop edge tools on them without even worrying about anything. They're pretty expensive. My shop cost about $700 to do the whole thing but it's money well spent. Had them in there for 10 years and they show absolutely no sign of wear. Just a lot of glue on them , but that's my fault.
