We value your privacy.
I was in Menards the other day and I noticed they had, in a new display, their version of the multi tool for 29.95. I didn't have time to look at them that day, thinking I'd come back later and check them out. Lo and behold a week later I went to take a look and the price had gone up to 99.00! He who hesitates is lost!!
Since those have come out I've wondered. I guess an info-mercial can make anything look like a "must-have". But I've never heard anyone say it was a "life-changing" tool. Meaning that it did everything they demonstrated WELL, for the buyer. Anyone here enthusiastic about them ?
Steve, I have a Bosch model that is battery powered. There is a fairly lone post on it down below in the Post about the HF one. I saw the infomercial on the Fien one and at $400 through it was an overpriced joke. Could not imagine finding much use for it. Then I caught the one at Lowe's on the close out table for $99 and bought it on impulse. Turns out the charger did not work well and Bosch sent me a new battery and Charger. So now I have three batteries. I have started remodeling house and have found a myriad of uses for it. Undercut door jams for hardwood or tile. Cuts drywall like butter. Sands into corners nicely. Cut slots and pockets in wood. Cut notches in the edge of deck boards for the posts. I am amazed at what we find to do with it. And, the saw blade basically won't cut your skin. The scrapers might if they were as sharp as a knife, with the saw you have to work at it to cut yourself. I think I would like a corded one just as well, but the batteries are andy and they run for about 20m minutes and recharge in the same length of time. This is not a tool you use for a long time so the run time has never been a problem.
The worst thing about all of them is the cost of the blades. They are outrageous. The Bosch will accept anybody's blade and I use the HF ones when I can. If and when this one craps out, I will get another one. I think the Fien one would be better but I still won't pay $400
I'll say I do have the Fein Model. And 2 HF models (one at my house, and one at mom's for those odd jobs when I am there).
The Fein is much much better than the HF model. However, both work.
I got the $400 Fein kit for $250 or so last year when they were changing what was in the kit. It's worth $250, but not $400 as you stated-I concur. The Fein comes with a lot of blades and stuff that cost a lot seperate. The toolless blade change I like. You can find the Fein tool only for like $179 but when I saw the Fein kit for $250, I bought it. The Fein runs smoother.
That said the Dremel, and the Rockwell weem to work well for the money according to my father who has used all 4 now (and is a contractor). The Dremel can be had recon for like $59-69 sometimes and I think I have seen it new for as low as $79. The Dremel and Bosch are both owned by Bosch I think but use different blades (you can buy an adapter at Lowe's I know).
What are they good for:
Undcutting door jambs when installing hardwood floor.
Making odd cuts in flooring, etc.
Cutting pvc pipe near a wall behind a toilet where you can move a hacksaw well (you can set the blade at a right angle to the tool).
Cutting out rot around door frame molding-think side door on stucco house that rots no matter what you do. The narrow blade gets in there and cuts it.
Using the scraper blade to cut out old caulk around windows to recaulk (I did one window by hand and used the tool a few months later, took 1/4 the time and my hand didn't hurt)
Using the diamond blade to remove grout when repairing tile. This is not used often
Cutting in electrical boxes in wood, drywall, etc.
It's a really good tool for remodeling and upkeep of a house. use in woodworking making furniture and such, not so much. It doesn't do anything you can't do with other tools that you normally use to the above. It just does it faster.
HF just had a coupon for like $17.99 for their tool. You will get your money's worth out it probably.
