OT: Battery Chargers
Stuart Johnson
Every new gadget, phone, camera, bluetooth ear thing comes with it's own charger. Right now I have at least four chargers all with the same mini usb connection that have an output of 5V but with 500mA, 550mA, .70 A and 1.9A. All will charge if the cord is plugged into a USB port on my computer and I have no idea what output it has.
Would it be safe to just use the 5V 500mA on all of them? Would I burn something out if I plugged in whatever takes the 500mA to the 1.9A charger?
Re: OT: Battery Chargers
Bill Howatt
My guess is that it would be taking a risk to use the high current charger on other devices. Sometimes the chargers are regulated, sometimes they aren't. Often the devices have internal circuits to properly charge the battery or run the device. If you plug in an unregulated charger that his too high a voltage under light load it could cause serious damage.
A standard USB2 port on a computer is designed to provide 500ma, USB3 is higher.
You should be safe using the 500ma charger on all the devices but you probably noticed the instructions telling you to use only the provided charger.
Bill
Not a simple question to answer
Bill Tindall
Modern batteries are picky about how they like to be charged and the details determine to a large extent the service life of a battery. The battery can be charged at constant current or constant voltage, or ideally, some combination of this two variables for the case of the best chargers. The electronics that may be in the battery as well as the electronics in the charger control these factors. Each battery type, as well as the details of the battery construction, will determine how tolerant the battery will be to the altering its ideal charging voltage and current.
Bottom line: Either charge with whatever came with the device or charge with the most expensive battery charger you can buy with the presumption that an expensive charger has the electronic controls to best charge a given battery type.
I'll use them all. Thanks.
John McGaw
Based upon my own experience and all that I've read mini-usb and micro-usb chargers are interchangeable. The key is that they all have 5V output which is identical to what the USB port or your computer puts out. The current rating is merely what the charger is able to put out -- it in no way suggests that it will force the device connected to take that much. The current going to the battery is controlled by the charging circuitry in the device being charged (most of the small devices actually have a 3.7V lithium battery). I have a handful of dedicated and worldwide-universal plug and auto 5V chargers with USB plugs and all of them are used interchangeably with no problems.
BTW the new worldwide standard for phone charging is the micro-usb plug. Of course Apple ignored the standard but they are, after all, Apple.
I agree with John
Dustmaker Mike
I would use the highest charger you have. The device will only take what it wants from the charger and no more. Each device will control the current draw to keep it from destroying itself.
Not an Electronic Engineer but and an Electronics Tech going on 35 years now and I did sleep at a Holiday Inn Express once(-;
