A handy dovetail layout device
Bill Tindall
Let me state up front that someone on Woodcentral sent me a picture of this device; it is not my invention.
The task: There are more than 6 dozen individual dovetails to be laid out for the front of the drawers in the chest I am making and about 5 dozen for the rear. All the pins for the front are the same size and all the pins for the back are the same size, but a bit larger ( and fewer). Furthermore, the spacing of the pins can be something less than perfect and still look fine. However, the size of the pins needs to be similar or the layout looks sloppy. That is a bunch of marking that can be made easy and result in perfectly sized pins. It is done by focusing on the pins, not the tails. To that end I name this thing an "Adjustable Pin Marking Gauge", even though I gang the drawer sides and saw tails first.
The device:
This example board has been marked as it would be for a drawer side, but the marks have been darkened so they show up better. The half pins are marked, then either by eye or by dividers the center of the pins are located. The gauge is centered, more or less, over the pin marks and the pin/tail marked with what ever you use for marking. I use a 0.5 mm drafting pencil or a 0.5mm gel pen on dark wood. This device not only makes short work of marking, but every pin will be the same size.
Detailed instructions for how I made the gauge are to be found on the Hand Tool Forum.
Re: A handy dovetail layout device
FredD
"This device not only makes short work of marking, but every pin will be the same size. "
Until you cut them in many cases :D
Hmmm. that could be a double entendre. Colonel ??
FredD
