Dovetail jig recommendation
Howard
I’m looking for a dovetail jig. Would be used for small boxes (5/16” wood thickness) with thru dovetails and blind dovetails in drawers (3/4” wood).
Another important factor in selection of jig is that I have almost a zero tolerance for reading instructions.
Thanks
Howard
Re: Dovetail jig recommendation
George Colonel's Workshop-Havertown PA
Hello Howard,
I use the P+C 4212 jig. It can do box joints, thru dovetails, 1/2 blind dovetails, and rabbetted dovetails. Can also do sliding dovetails. It takes a small learning curve. Once properly set up, its practically fool proof.
As to instructions, I read them before each jig use: no getting away from that. However, they are well written.
George
I have a Leigh Jig. I like it. Its one of the well known top of the line models. Very versatile. But, If you have a low tolerance for reading the instructions, forget it. The Book with it is good, but its about and inch thick. I use it frequently and have to start all over every time. "They" tell you to dedicate two routers to it and get them set up and leave them. Never works for me. I either change the thickness of the wood or decide I have to do some other type of dovetails and never get back to the standard setup.
Good Afternoon Barry,
One thing about the P+C 4212 is that if I do have to get away from the original set up, I can reset the depth adjustment from the jig, given I am using the same thickness of stock..
BTW Barry, I really wanted the Leigh jig because it was so versitile and permitted variable spacing between dove tails. I had the money, but the salesman thought I wasn't good looking enough. ;)
Jason Waters
I have the Leigh Jig. And if you don't like reading instructions, forget it. It does make beautiful dovetails, and oddly spaced, somewhat simulating hand dovetails.
I have used it several times, but it's a tool that will take me a long time to get my money's worth.
I got it at a show, and while I paid about the going rate, I got some extra bits and stuff that you don't get normally.
And while in use, I do use two routers, two PC 691's
Jason
Ray Newman
For through dovetails, the Keller Jig is very easy.
See:
www.kellerdovetail.com/
Will not do half blind dovetails though.
Leigh Vrs. Omnijig
Howard
Any idea how the Omnijig compares with the Leigh in ease of use?
Thanks
Howrd
TomD
I have the Leigh, and I don't use it much, but I never have to use the instructions to set it up for through dovetails. I use the tapered templates to help me see the joint I will cut. I set the spacing by eye and tighten it down. Then I flip the jig for the straight guides and cut that joint. I just mark the index on the beam with a pencil to align side to side. The initial cut consists of going around the socket with a climb cut, then just back and forth. Once all the tails are cut, I flip the jig for the tapered template that cuts the pins. The only trick is to set this back from the designated mark, you want the tapers to be more to the rear. This will make the pins fat. Cut them out trial fit and move the tapers forwards till the fit is perfect. Normally this requires one try after the initial cut, but once it is dialed in you can cut pins for ever so long you don't change anything. There is a scale that gives setting for typical thicknesses, but the trick for one-off work is to start a little fat.
The principle is really simple. Fit comes from moving the tapered template forward or aft to change pin thickness. Start with the pins slightly fat and work to a perfect fit. My joints have always come out, and they are normally all one off situations. I once made half-blinds in drawer fronts that came from the apron. A one off situation with little forgiveness. But it came out perfect. For one-offs, hand cut dovetails are probably a better bet, but a person has to get to that point for themselves.
AZ in Colorado Springs
I use the Leigh jig. We have one at the Air Force academy woodshop. I appreciate that I can adjust the size, spacing, and number of tails to the width of my stock on each project.
However, I don't like fussing with setting the guide for the pin board, so I cut the pin boards by hand. Also, regardless of the thickness of the stck, I can just use my one dovetail bit (the Leigh bit set has a couple of different dovetail bits with different pitches for different thicknesses of stock -- the book tells you which ne to use in each situation).
The instruction bok for the Leighjig looks intimidating -- it is thick as was stated in a different post. But, it's very well organized. There are separate sections for the different joints, and each step has an illustration.
I also have the Peachtree joint making set -- dovetail-type interlocking joints, but with templates for many different shapes. You secure the stock to the template, and pass it by the router bit using a router table. That's a pretty slick set up. The only downside I've found is that the female board must be at least 3/4" thick. I have not made dovetails using that set yet.
kellyanderson72
I have the Akeda and it works great. The instruction book is clearly written and easy to follow. The jig is very easy to use.
Re: Dovetail jig recommendation *LINK*
del schisler
this is the jig i have had sence it came out probly 4 yrs or more. It work's very well and set up is fast. 2 set up's and you are ready to make tales and pin's that fit. The jig cost $$'s but it is a good one. I use 2 tables and 2 router's that work out well . That way you don't have to change bit's. I use it maybe 3 time a week. I make jewelry box's and trinket's box's. It can be bought from japan wood worker here the link to show what it is.
http://www.gifkins.com.au/Jig%20Design.pdf
Nothing is as simple as a Keller, nothing!
Dick Coers
Once the jig is set, you never have to touch any setting unless you drop it.
gary peterson
I used hand cut then decided doing chest drawers consumed too much time. Purchased the Leigh 18 Super jig. Did one chest of drawers, sort of learn by doing. Worked out, more more practice. Unless using frequently time is taken up relearning. But, if doing many drawers etc the jig could be helpful. Clients don't exactly care I hand cut their dt's, just that they are dt's.
Re: Nothing is as simple as a Keller, nothing!
FredD
I couldn't agree more Dick, it's a Jig to love and protect from people who want to "borrow it"
FredD
