OT TV on the computer
Went to Hulu and watched a TV show I missed. That went well. then tried to watch one that had aired a few days ago on CBS. Worked fine for a few minutes, then it froze. Sound was fine but the picture just sat there. Closed the screen and tried again. Same thing. Several times. Froze in different places but always a few minutes into the show.
Any idea how to make it work correctly? Kinda nice when it works.
Re: OT TV on the computer
Dale Lenz
Buffering...
Dale Lenz
I believe it's called. You need a faster connection. Sometimes I'll put the video on pause and do something else for a while. The video keeps on downloading while I'm occupied doing other things. Come back and watch the movie, at least some of it until it buffers again. If your lucky, the movie/show will not buffer any more.
Re: Buffering...
Interesting. I have Comcast Cable and Internet. I don't know what he speed is, but I have heard that it slows down when lots of neighbors use it at the same time. Maybe that is what was happening. Wonder how I can pin it down?
Re: Buffering...
Stuart Johnson
Berry, before trying to download open a second window and go to Speedtest.net and check your speed. Leave the window open and when it stops flip over and run the speed test again. I run into a similar problem with Netflix from time to time. Netflix says it's a Roku issue, Roku says it's Netflix and when I convince both the other is working they say it's a problem with my router. As far as I can tell it is just gremlins that at some point wander off to pester someone else as it clears up but nobody has done a thing.
Re: Buffering...
Craig Daymon
Barry,
There are many things that impact the speed at which you will get the program data (everything on the internet is data of one form or another). Pictures that add no relevance to the topic, video advertisements running in the sidebars, audio that plays whether you want it or not.
That aside, if you are watching a show and it starts to show the behavior you saw, try pausing the playback. It will (should) continue to buffer the show on your computer and when it completes you should be able to click play and watch it without interruption. While it is buffering, you can read messages on Wood Central or read other sites. I'd avoid trying to watch other videos while it is buffering, just to speed things up. This has worked well for me.
-Craig
