We value your privacy.
I just empted the bag on my dust collector and put the empty back on. Anybody have any suggestions on how to replace the bag by yourself? I think it is a two person job but wondered if anybody had any ideas on doing it by yourself. I seldom have anyone here when it needs changing and wind up doing it alone. Hard to do.
Just wondering. I was thinking of drilling a series of holes about 2" up with bolts sticking out to hang it on while I put the band clamp on. Whatcha' think? Any other ideas?
I built a Thien Separator so I don't have to empty the bag, plus it keeps all the debri out of the impeller. But if you don't want to do that I've seen somewhere where someone fastened clips to the side of the bag ring to help hold the bag up while reattaching it to the DC.
mine is a delta i use the band that goes inside the bags instead of the band's. The rings that go inside of the bag's work's good . the band's i saw was going to be a bitch to use so i went with the ring's that go inside the bag. Don't you have those. What you do is put the ring inside the bag and fold down some bage and inseart in the unite with the ring fitting on the collector their is a inseart top and bottom. that is what i use. I have a 30 gal seperator in between so i don't have to empty the bag on the collector. go here and look at the part's view and scroll down to #23 the one is the cloth covered band clamp not the clamp one
I have a Delta DC and it is outside the shop in a little exterior closet. (Putting it outside was a major improvement, any dust it collects is outdoors, both the course stuff and the fines that may blow through the filter and the part I spill while changing the bag.)
Mine has little clips that hold the bag while you put the strap clamp/belt on it. the work well.
the other thing I did was buy a 30 gal(?) trash can and sit it under the DC with the bag in it. The can is about four inches short, so the bag is exposed at the top, giving me a view of it so I know when its full. Then I drop the clamp down around it, unclip the bag and fold in the top. Then I sue a hand truck to roll it away. The hand truck came from Harbor Freight and is a piece of crap, but works great for this. If I had set it up a little better I could leave the hand truck strapped to the can all the time.
The other thing I need is some sort of sensor to tell me when the bag is full.
I bet you could buy the clips from Delta and bolt them onto yours for a few bucks. Mine has four but two might be enough and three would certainly do the job.
I cut a hole in the top of the bottom bag and ran a plastic tie rap around the metal band. This helps me get the bottom bag out. To put the metal band around the top bag I use rare earth magnets to hold it.
