Somewhat OT - granite tile
I'm going to be removing the old granite tile in my kitchen pretty soon. I can get some reasonable squares out of it (hopefully).
Is it worth saving for future use in a furniture project (table top or the like)?
The tile is about 12" x 12".
Re: Somewhat OT - granite tile
BTDT
Make the table top out of 3/4 MDF (90#) and glue your tile down with 1/16" gaps. Leave a 1" area of MDF around all sides. Let set up for a few days (week is better). Mix colored epoxy to match/complement your stone and fill the gaps being careful to keep the tile clean. Dam the open ends of the gaps with putty or soft wax that can be removed. If you do get epoxy on the top surface, wipe it off immediately with a paper towel moistened with alcohol - DO NOT use acetone as it will attack the sealer/filler used by the factory to give your tiles their final polish.
When set and filled, edge band/frame your tile section and mount on the table frame.
I've done this with marble (Dark Emperadore+Walnut) and granite (Blue Eyes + Maple). Makes a nice table.
Ditto
Bill Tindall
I use rock tiles to make tables. Some the rock available now days melds beautifully with various woods, or example the softer sedimentary rocks with maple and white oak or the redish gneiss with cherry. But, you apparently hate this rock, so it would seem unlikely that you would find it attractive in a table. I can't think of any other use.
Dave Bair, Eaton Rapids, MI
Set them in a frame of wood and felt the bottom to make a primo trivet.
Re: Ditto
If you do hate them too much to use as a table top, save some and use the as backing plates for a sharpening station. Glue some sandpaper to them and Bob's Your Uncle.
Personally, I would make a table out of them.
Jesse Cloud
I used some to make a buffet for our dining area. Its nice to be able to set a hot dish down on the tiles without using a trivet or anything.
Another good use is on your grill. Clean it up nice and put it on the wire rack while you are preheating. Makes a great platform for cooking shrimp and other small stuff without fooling with skewers. It will crack eventually, but it didn't cost anything to start with...
He Didn't Say
He "hated" them, merely that he was "changing" them.
So SWMBO wants the color changed. No Big Deal, and no hate involved here. Consider, friends, if he/they actually hated them, why would he be trying to save them intact and asking how to reuse them?
Sheesh :(
