We value your privacy.
I'm building a set of chairs to match my new kitchen table, and want to use epoxy and screws to tie the legs to the seats. Using Red Oak for the seats and Black Walnut for the legs. Can someone who has been successful using West Systems products make some suggestions to lessen the learning curve, and maybe prevent mishaps?
Doug, I really wouldn't use epoxy for chair assembly. Reason being it is just a matter of time until ANY glue will break free considering the stresses on chair legs / seats during use. I always use Hide glue for that application, Hide glue is stronger than the wood itself and in a proper joint should last several years. The main advantage is that when (not if) the joints loosen, they can be repaired with little work and will last as long after repair as they did the first time. Epoxy does not adhere well to itself after the joint has loosened. At that time you would have to remove all the old epoxy, shim up the joint and re-glue. Hide glue will adhere to itself over and over. I have successfully repaired several Heirloom chairs for my relatives - all had been assembled with hide glue and after re-gluing (did have to add some plane shaving shims to tighten the joints) they were as good as new.
The joints for most of my chair stretchers are round tenons - though I use rectangular tenons on occasion. The joints for legs into the seat are usually tapered wedged tenons. I've never really had call to use epoxy. I have used foxed tenons for stretchers on occasion as well as wedged through tenons.
This isn't an answer that will be received with delight, but I suspect that any chair design that depends on epoxy and screws may need rethinking. If I was building my first set of chairs I would be sticking to a design that had stood the test of time. I suspect there is a good reason that there are but a few chair construction techniques that are commonly used.
I don't understand the use of screws either, but if you do use epoxy, don't fit the tenon too tightly. Epoxy likes a small gap to really do it's job. Make it too tight, and the epoxy wipes off and fails.
Sorry, fellows, I should have asked the question differently.
I wasn't asking for a critique of my design, or someone's acceptance of my choice of material, I was asking a very specific question regarding any tips and/or methods someone may have used to control weepage, and the potentially messy tendencies epoxy has. I'd rather not need to do a lot of cleanup.
Referencing " a design porblem", it oftentimes irks me when a few folks routinely make unwarranted assumptions when posting replies here. They need a reality check, it seems. Simply because someone posts a reply to virtually every post on the board doesn't qualify them as an expert. Maybe your horse is too high, huh?
Actually, I have been woodworking for more than forty years, and folks that know me consider me a pretty accomplished woodworker. I don't routinely post the things I make, because I don't need the ego boost, but that doesn't mean I can't make an informed, logical decision as to the practicality of an approach or material choice. I purposely intend to incorporate many of the inherent advantages epoxy has over other adhesives in this design. Because it's a bit unconventional doesn't make it wrong, gentlermen, it just makes it different.
I appreciate the replies that addressed my question, and were made in a positive manner quite a lot.
Well Doug, I still don't have any idea how the legs, seat and apron are joined, but I do use a fair amount of epoxy. I almost never use it straight out of the bottles, without thickening it, with various additives depending on the application.
You can control the sag by either mixing it thicker, and then by masking off the area outside the joint, then fingering off the squeeze out, with a gloved hand, then peeling the tape anytime before it hardens.
You can make it as thick as latex paint, for using a roller application, catsup / mayo / peanut butter, and on up and still have a really tough final product.
I have a boat repair job going right now, where I will be using it in all of those thicknesses, plus straight, to wet out some fiberglass cloth.
Thanks, Keith. I have used it as a structural element in the past, and have thickened it with a variety of different materials. I guess it's time to finally use the thickener they sell with it.
I had envisioned taping off all of the adjoining surfaces, and that's a good idea. I also thought about using tape to create a "dam" around the joint, and using the really thin mixture, but I was afraid it would wick out and create a mess.
Doug, Next time you mix, with whatever is left over, mix enough filler to make peanut butter viscosity, then glue in a test piece that you can destroy for your own QC.
is use wax around the joint. Wipe the wood around where you don't want epoxy ( I hold the pieces together and apply wax to keep from getting it in the joint) and then glue up. When dry, a chisel will pop any epoxy that squeezed out right off. I used this technique on a chair that had experienced a glue line failure between two boards ( not a joint) and it cleaned up without affecting the finish.
I also rely on a friend who sells and uses West system epoxies - he advised me to wet the bare wood in a joint with the thin epoxy as first mixed and then add filler to thicken the mixture and apply this to the joint. He says if you use only the thickened epoxy in the joint, there isn't enough liquid to soak into the fibers on the surface. Its worked for me.
Good tip on the wax, Diz. I suppose it also requires the finish to be applied before glue-up as well. I found the tip your friend offered myself many years ago using the cheap epoxy from the hardware store when I was filling voids in turnings with Turquoise and brass filings. I had a filling come out at high speed and bounce off the ceiling.
