We value your privacy.
There are a lot of edges on 7 drawers and I like to soften them all. I don't like touching a sharp edge in furniture. I've tried block plane, spoke shave, sand paper. Yet another one of those things I have not settled and await sage advice.
Finish sanding the surfaces before you start the softening process. That way, whatever you do to the edges won't be lost when you finish-sand the adjacent surfaces.
Edge treatments have both shape -- e.g., round-over vs chamfer vs something else -- and size, as in the size of the radius or chamfer. If there is a need for a certain feel, then that will impact your choice of shape and size.
Uniformity is key. If all you want to do is just kill the edge slightly so it doesn't cut you, I suggest wrapping a piece of fine sandpaper around a piece of leather to create a flexible edge-sanding block. Fold this over the edge and sand carefully, keeping an eye on your progress so you don't soften too much in any particular area.
My LA Mathers Radi-plane is probably the same thing as the LV. The Mathers had two adjustable blades in a wooden body. As long as you go with the grain, it is great. When the grain is a little wild, it can be tricky. None the less, it gives a very uniform small radius edge.
Expanding a littel on Ellis , it has been my understanding for years that the East Coast preferred crisp edges and the West softer ones. That may be pure BS ,but it has been stated over the years in amny Wood Mags.
For myself , I don't like crisp edges because they damage more easily then rounded ones and leave very little surface for film finish.
Many times I start out with a carbide 1/8th inch rounding over bit and then clean it up with finish sanding. Less sanding that way and very uniform in appearance.
If I want a mini-chamfer it's with a block plane or file followed by a touch of sandpaper if needed.
Alternatively I also use a 1/16" round over bit in a laminate trimmer and a file to get in the corners. Shop I used to work for always used 1/8", but I found it a bit too big for my own taste.
Set up a sacrificial fence on the table saw. Raise blade about 1/4" and tilt to 45 so it cuts into the fence. Just slide each edge down the fence. Adjust size with test pieces. It's very fast and looks good.
A block plane leaves teh smoothest eased edge, barely visible to the naked eye but you can feel it, set fine and make 3 or 4 passes. If you had 12 boxes to do it seems like it would take a while but I bet if you just did it you would be done in 30 minutes or an hour.
while I am sanding the edge, then just tilt 45º and knock the corners with a quick pass. When doing the insides, care must be taken to not let the paper hit in the corner. If you bang into the other side, it will not only wrinkle / tear the sanding disk, it can damage the edges of the pad.
A little abrasive scratch can improve getting the finish to stay there, rather than shrinking away as it does on sharp slick corners.
I soften the dges on most of my work. The easiest and fastest way I have found is simply by hand with sandpaper. What I use are used 5" sanding discs from my ROS. I simply fold them over into a half moon and push them into my palm. I just take them along edges at a 45 degree angle in a circular motion. Fast and simple.
Any plane that I have close by that is not too large so as to be ungainly doing the job. If I only had a spokeshave out, I would use that, but that hasn't happened yet.
I keep a 1/8-inch RO bit permanently installed on my laminate trimmer for rounding over edges. If I want to just break the edge, I use sandpaper and a cork sanding block and just take a few uniform swipes. Works for me. I do have a 1/16-inch RO bit, but can't say I have ever used it.
