Setting the record straight on acetone
Bill Tindall
I often wonder where the paranoia over commonly used chemicals comes from. It would seem in this case misleading or misinterpreted information from a trusted source, namely "the doctor". Unless the doctor has specialized beyond the limited chemistry they may have been required to endure as an undergraduate, they are no more qualified to interpret toxicology data than anyone else with some exposure to chemistry, and this presumes they have at least read and understood the MSDS for a chemical in question.
So, step one in dealing with any chemical is to read the material provided on the container. Step two, obtain, either from the manufacturer or off the internet, the MSDS and study it. These sources of information are the most reliable to be had. In the case of acetone, it is so commonly used that there is also a great body of information that results from experience using it in manufacturing.
After studying the available data then decide what your short and long term exposure is likely to be and take appropriate precautions guided by the information in these sources. Keep in mind that the short term exposure amateur woodworkers are likely to encounter is vastly less a threat with most chemicals, than a worker exposed for an 8 or 12 hr shift.
Indeed, the conclusion from all the sources is that among the solvents acetone poses a toxicology risk not much different than ethanol and less than many other commonly used woodworking solvents. Exposure at a concentration where there could be short term toxicity would be a situation where flammability would be an alarming concern.
That said, it is never a flawed practice to minimize exposure to solvents both for toxicity, and more relevant, flammability concerns. The often encountered statement of "use with adequate ventilation" is well founded. A good rule of thumb is to treat all woodworking solvents as you would treat gasoline. Most are not quite as flammable nor quite as toxic as gasoline.
The issue of gloves and solvents is not a simple one to decide. Some gloves are permeable to solvents. Other gloves are clumsy and could lead to spills. An undiscovered leak/tear in a glove can lead to concentrated exposure and irritation (been there and done that). Personally, I don't use gloves with solvents. None of the solvents I use present any significant risk of harmful exposure by short term contact to the skin. They all evaporate so quickly that any accidental skin contact is very short term.
The exception is stripper containing methylene chloride. I use it with heavy impermeable gloves because contact over extended time will result in severe irritation.
As an aside, when one of my sheep's breath smells of acetone they are on death's door, not from the acetone, but from the fact that their metabolism has gone amok and their cells are making acetone and not CO2. Treated promptly with either glycerin or 1,2-propane diol ( one variety of antifreeze) they can recover in minutes. The alternative it too gruesome to describe on this Forum. The chemistry of the cure is interesting. Six ounces of these chemicals into the rumen provides the cells with a prompt energy source equivalent to an IV of glucose.
