Anybody ever mount a dust collector upside down?
Rob Sandow
I have 2 small dual-bag type 1/2 HP or so dust collectors in the shop. They have nice felt bags on the top and plastic bags on the bottom. I have been trying to fit out a much reduced size shop for a few years now and just not finding the floor space I need. It occurred to me over the weekend that I could maybe turn these upside down and mount them to the ceiling along opposite walls, then reverse the positions of the 2 bags so the felt bag still points up and the plastic bag still hangs down. Probably rig up some kind of shelf on the wall to support the bottom bag. Anyone see any issues with this?
Re: Anybody ever mount a dust collector upside down?
Let me see if I get this correctly. You have double bagger DCs with a plastic bag and a felt bag. You want to mount them so that they are upside down - using the base metal plate presumably as a mounting plate.
If the impeller unit is like my old DC - I see no reason why you can't. The impeller unit connects to the bag units via a large hose at the center of the bag "ring". It really doesn't care where the bags are. There is a caveat to this though - the plate that was on my old DC was a bit flimsy. I don't know if I'd trust it to hold a vibrating piece of machinery upside down.
Yonak
Rob, my Powermatic dual bag DC has a chamber to collect heavier items before they get to the bags. This feature would be defeated if I were to mount it upside down. Could you build a wall-mounted shelf for the DCs to set on right side up ?
Also, have you thought about changing the bags when they are above your head ? It could be a bit tricky. Also, the dust may tend to fall in your face. I would consider this idea carefully. My 2¢.
Another caveat - make sure that you have really strong plastic bags.
Jesper, Denmark
Jesper, Denmark
The splitter or vortex finder that connects the two bags and the air inlet probably has baffles in it, directing the heavier chips downward. This would be defeated if mounted upside down.
If you can take it off and remount it, so it still is the right way up, it might be OK. Look inside and see if there are any baffles.
I'm imagining how much fun you'll have if the weight of the plastic bag filled with chips overcomes the holding power of the clamp. Don't most of the plastic bags rest on the base of the dust collector in use, so that only a little weight is carried by the clamp?
If you do this, plan for some kind of support for the bag in addition to the clamp.
