We value your privacy.
I have borrowed a vac. bag from a friend, and enormous affair 4.5' square. It is a cumbersome affair for doing a 6 x 27" drawer front.
What I would like is a bag just for drawers, something that would accommodate a drawer up to 9' wade and 36 long at most.
1. Can I make a bag from readily available materials?
2. Does anyone sell a bag sized to drawer fronts?
3. Better yet would not be a bag with its clumsy sealing system but a box with some sort of lip seal. Has anyone made some sort of frame or box that could be sealed over something like a drawer front. I am envisioning something like a solid bottom with some sort of seal and a frame with flexible sheet that would be placed over the bottom and the two parts would seal under vacuum.
We had a 4' x 8' bag, a little bigger actually to allow for forms to be inserted, and put it on a 4' x 8' table. Then we put a 4' x 8' sheet of melamine in the bag with 1/8" deep slots cut every foot in both directions. Anything we needed to veneer or bend on a form was imply inserted in the bag, the end was shut with a pipe and clip made for it, and the pump turned on. It worked very well, was simple and quick. You can see the link below for the vacuum system we used.
Vac bags are available in all sizes and you can make your own. The best place to start for either route is the veneering guru Joe Woodworker.
A second approach is to simply roll up the excess section of the bag, clamp it stable with a couple of spring clamps and go from there. This will make it shorter in one dimension.
I remember someone here mentioning that you can use upholstery vinyl to make a bag. He said the best place to look for it was an auto upholstery supplier, though I remember people having their couches covered in it too. At any rate, any heavy clear plastic would likely do it. You can fold over the edges and clamp them between two battens if you don't have some kind of heat sealing apparatus available.
Personally, I do drawer fronts with clamps and cauls, good excuse to pick up a whole bunch of Wetzlers (assuming you can of course). The only real advantage to bag veneering is that the pressure is very even, so it lends itself well to doing large surfaces that would be difficult to clamp. Depending on your pump, you may only develop 10-12 psi of clamping pressure, but it will be very even.
The other trouble I found was that when using plastic resin glue it had a tendency to boil anywhere there was a void (like around corners of the piece where the bag couldn't suck all the way down). This made for weak glue right where it needed to be strongest - corners and edges. We had much better luck with 2 hour epoxy.
I don't really understand the box concept. All you need to do is have a bag with all the atmosphere sucked out, so that the weight of the atmosphere outside the bag does the clamping. While you could probably come up with a workable design, it seems to be making it overly complex to me.
I ordered supplies from Joe's and made my own bag. I ordered a huge bag with my press to accomodate the side of a dresser. That is pretty much overkill and cumbersome for 99% of my other projects. I think Vacupress sells a commercial version of what you described. I bet you could make your own scaled down version with materials from Joe's. My original is a Vacupress. They are great to work with. Lot's of great info at Joe's web site.
back in the eighties sometime. I was inspired by an article in Wooden Boat Mag, and was doing some boat work back then, so epoxy was the glue choice for that kind of work, and it works well for non nautical work as well, and I always have it on hand.
I have always made my own bags. When I buy sheet vinyl, from an auto upholstery supply, I also get a can of contact cement for gluing the seams.
But I have done jobs too large to be able to get into a bag, where I made the bag around the parts, using carpet tape, and butyl caulk to seal one-off bags
I made a table set up once, but quit using it. When I do curved work, I like having the form outside the bag, which is a lot easier. And when I am doing flat work, I make sure my substrate is flat, not depending on the veneer to do the flattening, so just using bag that I can roll up and stick on a shelf suites me better than another fixture taking up square feet of shop space.
My normal bag is about 54" wide, - 1.5" off each side, x 10' long. I seal it by folding the end over a piece of 1/2" copper tube, then sliding a slit piece of 3/4" pvc over it, then roll it up a few turns, then clamp a couple of pieces of lath to it.
I have done doors and drawers just using drum liner bags, with a hose run through a clipped off corner, then sealed the end by rolling it up on a lath, with another lath clamped over the roll.
I could make you a single sheet of plywood with a marquetry face, the size of a tennis court, with as much curve as the individual plys will bend, in one glue-up if I had a patron willing to challenge my creativity. I know that sounds bold, but once you master a few basic things, like glue setting time / temp. bagging opens a world of possibilities.
