OT - I need to make a compressor gasket
Ralph Lipeles
I have a 15 year old DeVilbiss 6 HP compressor. It was taking a long time to come up to pressure and when shut off the compression slowly went down to zero. I pulled the head and found a bad flapper valve. Flapper valves are still available but the 2 top end gaskets are not. So, I will need to cut new gaskets. They are approximate 4" by 7" by 1/32". I have cut gaskets before, but do not know what kind of gasket material to use. I appreciate any material suggestions.
AThank you,
Ralph
Re: OT - I need to make a compressor gasket
Many years ago I decided to work on my compressor for some reason I have forgotten. While reassembling it I decided I should leave the carry handle off as I never used it. Unbeknownst to me the handle served as a spacer under one of the bolts. The bolt appeared and felt tight, but it had bottomed in the hole with about a thousandth of an inch of space left. Blew the head gasket. POW! Bought a generic piece of gasket that appeared similar and used the old gasket to cut a new one. If my dim recollection is correct, I coated it with Permatex for no reason other than I had seen my father use it on farm equipment. I put it back together with the handle and its been fine for many years.
woodenleg
Some hardware( old fashion) and auto parts stores still carry gasket material. If that is not possible an auto parts store should be able to suggest something. You might want to check a shop that rebuilds compressors, a/c, refer etc.
Dave
Make your own
iew
Get gasket material of your choice. Lay it on top of block and use a small ball peen hammer, peen end, and lightly tap around edges. You should be able to just punch out by hand the patterns.
Ralph, NAPA (automotive) carries gasket material in various thickness and properties, any material used in automotive applications should be adequate for compressor use (heat rating / oil resistance etc.). I would measure the thickness and purchase a material as near as possible to the same. You can use the copper/silicone gasket sealer if you want (I would). It should insure a tight seal if the milling is a little rough on the castings. Shouldn't be hard to make a gasket to fit with careful use of a ballpeen hammer.
