OT - Flashing a Replacement Window
Ken Krawford
I'm replacing a rotted double hung window. My house has an EIFS stucco veneer. The replacement window unit has a PVC brick mold attached. I have found many and different recommendations for flashing around the new window.
What's the wisdom here?
Thanks !
Re: OT - Flashing a Replacement Window
Be careful Ken. EIFS has a dismal history. You probably already know that. One of many problems with it is that the windows MUST be rated for use with EIFS. The window must be flashed properly. Also, there is still some 'Old Style" EIFS out there and some of the newer version. The newer stuff has an internal drainage plane.
The window should be flashed so that any leakage will harmlessly drain out the bottom without coming into contact with the framing. This is unlikely to be as simple as removing the old window and inserting the new one, but it might be.
Unlike virtually every other siding we use, EIFS is a skin system and relies on the skin being completely water proof. At least the old stuff did. That turned out to be nearly impossible and the results were many disasters.
Time to do some research. Might be wise to check with local Code Officials. Also a good time to find a local Pro who really knows what they are doing.
If your wood window rotted it probably leaked water into the substrate and you may have leaks and damage around the window. Investigate carefully when you remove the window. If one window rotted you probably will find others.
FredD
Well Ken , Barry mentioned the downsides to that product and you likely have dry rot in more then one location.
This is a outstanding example of how bad departing from Standard building materials and installations of long standing success like real Stucco.
If this had a been a true three coat Stucco, your protcol would have been remove the old window and install the new one even with the back of the Stucco or face of framing. I am speaking of the Sash it'sself, then install the brick or Stucco molding and have a Stucco patch guy fill in with glued Stucco.
A good repairman can make it invisible and not have it develpoe any Shinkage cracks.
