We value your privacy.
I have a Delta 13" planer. It is plugged into a grounded outlet. I am using a portable shop vac for dust collection....also plugged into a grounded outlet. Last week we had low humidity and the static electricity all but made the shop vac nothing but a racket maker.
Is there some way I can eliminate the static electricity so that my dust collection effort has some value?
My shop vac used to give me a heck of a bite from static electricity. My brother suggested a ground of some sorts. I rooted around and found a short piece of light weight chain to screw to the base of the vac. It would drag around but not jam under the wheels. Ever since...no biting!
Pick up a bottle of fabric softener (like Downy - only you can use the cheap stuff), dilute it with water and use a spray bottle to spray the hose and all plastic parts. You might want to run the vacuum and spray a small amount into the hose (don't use too much unless its a wet dry vac). This will cause the parts to draw moisture out of the air and prevent static buildup. Should last for a few weeks - you can always reapply as needed. This works on carpets, clothing and any plastic items you have problems with during dry conditions.
I would be worried that any water would cause the dust to stick to the pipe causing other problems and possibly mold. Can't say it won't work I just don't think I would try it. The dragging chain works on cars. I believe it would work on a dust collector as well.
Sorry, I don't see where this would cause any problems with mold or sawdust sticking. I have used my shop vac many times as a wet vac in applications such as floor cleaning, carpet in my car etc. and have had Zero issues when returned to its function as my router table collector or general sawdust cleanup. I have a 3 hp. cyclone hooked to most of my equipment, but use my shop vac for the router table and general cleaning. In my past life as an Engineer, we used the fabric softener by the 55 gal barrel to eliminate static problems with product plastic bins, trays, table tops, assembly belts and even carpeting in the offices. The film that remains after the water evaporates is actually not visible or detectable to the touch.
